Scheme Editor Error opening browser in Ubuntu 20
Forum Home › Forums › Understanding the Software › Scheme Editor Error opening browser in Ubuntu 20
  • #7347
    Romanljw
    Hi, I meet a problem that the scheme editor can’t work on my computer. VMvare 15.52 was used to visual a computer, and Ubuntu 20 was installed on the visual computer. Then Rapid Scada(5.8.1) was installed and configured.
    The web station can be opened via Firefox. but when I started the scheme editor using root account, an error sayed “Error opening browser: Cannot find the specified file”. Then scheme editor opened, but I cann’t establish a new scheme. When I click the “New scheme” button, there was no response. The log of scheme editor is as follows:
    2020-10-05 14:00:17 <MyVPNServer><root><ACT> Initialize common data of Scheme Editor
    2020-10-05 14:00:18 <MyVPNServer><root><ACT> Load components from files
    2020-10-05 14:00:18 <MyVPNServer><root><ACT> Components are loaded from the file /opt/scada/ScadaWeb/bin/PlgSchBasicComp.dll
    2020-10-05 14:00:27 <MyVPNServer><root><ACT> WCF service is started
    2020-10-05 14:00:41 <MyVPNServer><root><EXC> Error opening browser:
    System.ComponentModel.Win32Exception (0x80004005): Cannot find the specified file
    at System.Diagnostics.Process.StartWithShellExecuteEx (System.Diagnostics.ProcessStartInfo startInfo) [0x00129] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0
    at System.Diagnostics.Process.Start () [0x00038] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0
    at (wrapper remoting-invoke-with-check) System.Diagnostics.Process.Start()
    at System.Diagnostics.Process.Start (System.Diagnostics.ProcessStartInfo startInfo) [0x0001e] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0
    at System.Diagnostics.Process.Start (System.String fileName) [0x00006] in <a85c1a570f9a4f9f9c3d2cfa5504e34f>:0
    at Scada.Scheme.Editor.FrmMain.OpenBrowser () [0x00070] in <1d900a6189354913afd7c5168087559a>:0
    2020-10-05 14:15:45 <MyVPNServer><root><ACT> WCF service is stopped
    2020-10-05 14:15:45 <MyVPNServer><root><ACT> Scheme Editor is shutdown
    #7352
    Check the editor settings that a default browser is selected.
    I recommend editing Rapid SCADA projects on Windows then upload them to Linux.
    In the future, Microsoft doesn’t plan provide .NET Forms on Linux Desktop, so the full editors will be on Windows, and may be we will provide a simple web editor.
    #7355
    Romanljw
    Thanks a lot to you kindly reply. I’ll try to config the settings. It seemed effective.
