Forum Home › Forums › Communicating with Devices › OPC › Communication with kepware OPC on window 10
- This topic has 11 replies, 4 voices, and was last updated 5 years, 6 months ago by
September 22, 2020 at 3:25 pm #7302
NITI
ParticipantHi everyone,
I’m having a trouble about communication with kepware OPC on window 10. I’m using Rapid SCADA vesion 5.1 and KEPServerEx 4.5. I used to try it on window 7 and it worked successfully, but it didn’t work on window 10.
Here is the error:
“Error creating data reading subscription: Exception from HRESULT: 0x80040202”Hopefully someone knows how to resolve this problem.
Thanks everyone.Best regards,
NITI
September 23, 2020 at 1:13 pm #7303
MikhailModeratorSeptember 23, 2020 at 4:42 pm #7304NITI
ParticipantHi Mikhail,
Thank you for your response.
The KEPServerEx which I’m using it provides OPC DA.
Here is its link: https://www.kepware.com/en-us/products/kepserverex/By the way, I’ve tried to fix the error by following your links, but this error still happened.
Please let me know if you have any further clue for this case.Your sincerely,
NITI
September 24, 2020 at 2:16 pm #7305
Talking about the link 3, what did you do and what results did you get? Please provide more info.
September 29, 2020 at 1:54 pm #7315kumajaya
ParticipantKEPServerEX 6 expose all tags as OPC UA tags.
September 29, 2020 at 2:07 pm #7317
MikhailModeratorI strongly recommend OPC UA instead of OPC classic when possible
September 29, 2020 at 2:28 pm #7321kumajaya
ParticipantBut now I still fighting why KpOpcUa failed to access NodeOPCUA server with BadIdentityTokenInvalid error. I’ll open a new thread about this problem later.
September 30, 2020 at 9:21 am #7326
MikhailModeratorI’ll open a new thread about this problem later.
OK.
April 9, 2021 at 9:52 am #8688tranduong257
ParticipantHi every one,
I have a trouble when connect Rapid Scada to Kepware OPC v6. I have choosed the tag from KepEX but when I click upload configuration, it’s said that “Error uploading onfiguration, there was no endpoint listening at http://localhost:10002/ScadaAgent/ScadaAgentSvc/ that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more detail”.
Can you tell me what would i do? Thank you!April 9, 2021 at 1:08 pm #8693
It’s not related with OPC. You should start the Agent service. You can find it in Windows service manager.April 10, 2021 at 3:41 am #8702tranduong257
Did you mean the ScadaAgentService in the path Task Manager > Service > ScadaAgentService? I have started it yet, but up load configuration not works 🙁April 12, 2021 at 1:30 pm #8710
You should select an appropriate topic to discuss this issue or create a new one. As I wrote, the cause is not related to OPC and Kepware.
