Hi all,
i would like to make a demo system, simulating 9-10 tags for 24 hours and then repeating them.
1. Should i use the KPSimulation Module? (How do we use it to generate data?)
2. Shall i generate the simulated values in a database and the import them via DBImport module?
3. Or is there another tool/solution you know, which i could use for this purpose, like a Modbus or OPC simulator, where i can set the value range and read them then via modbus or opc into RapidScada?
