Forum Home › Forums › Communicating with Devices › communication error
- This topic has 7 replies, 3 voices, and was last updated 5 years, 11 months ago by
September 15, 2020 at 8:55 pm #7279
joeh6966
Participanthttps://ibb.co/KqSPt49
I have been using rapid SCADA for most of this year successfully, and today it stopped communicating with my router/computer. It also doesn’t work with powerconfig. I tried using a new ethernet cable without success.
I have a Sentron PAC3200 meter still working in the basement.
Any ideas for me?September 16, 2020 at 1:28 pm #7280
MikhailModeratorA device 192.168.0.103 rejects the connection. The problem is on its side.
Try to connect to the device using another application.September 16, 2020 at 2:01 pm #7282joeh6966
ParticipantI did that before I wrote to you. Powerconfig from Siemens is a free app that used to work, but now also doesn’t connect.
Perhaps I should write to Siemens about this.September 17, 2020 at 11:45 am #7287
MikhailModerator“Have You Tried Turning It Off And On Again?” 🙂
September 17, 2020 at 1:25 pm #7289joeh6966
ParticipantYes, I did reboots of all devices including the PAC3200. Then yesterday I played a round of golf. So today I will write to Siemens.
September 30, 2020 at 3:24 pm #7328SGG
ParticipantHello Mikhail,
I am experiencing some communication setbackThe properties if my device under communication line containes the required values from my remote device.
from the server, the current data is not displaying the same values. all the values for 104, 104, 106, 108 etc from the communicator is 0. image is shown below
The server log indicates that all is fine as shown below
Please, how do i correct this error so that the current data under the server will show the same values see in the device communicator.
September 30, 2020 at 3:29 pm #7329SGG
communicator data from remote device
https://ibb.co/n0ykzT6Please, how do i correct this error so that the current data under the server will show the same values see in the device communicator.
October 1, 2020 at 10:01 am #7334
Please make a screenshot of the Input channels table where we can see the mentioned channels.
