Forum Home › Forums › Understanding the Software › How to use Notification plugin?
- This topic has 10 replies, 3 voices, and was last updated 5 years, 3 months ago by
October 1, 2020 at 5:19 am #7333
kcks66
ParticipantHi Mikhail,
I downloaded trial Notification plugin. However, I couldn’t understand how to configure it.
I successfully configured an input channel to show Alarm High. The input channel number is 612.
The Notification plugin xml file:
<?xml version=”1.0″ encoding=”utf-8″ ?>
<PlgNotification>
<GeneralOptions>
<EvPeriod>1</EvPeriod>
<DispNotifCnt>100</DispNotifCnt>
</GeneralOptions>
<NotifOptions>
<InfoCondition>
<Statuses>612</Statuses>
<ParamIDs>11</ParamIDs>
</InfoCondition>
<WarningCondition>
</WarningCondition>
<ErrorCondition>
</ErrorCondition>
</NotifOptions>
<Tips>
<Tip>
<TipCondition>
<Statuses>13</Statuses>
<ParamIDs></ParamIDs>
</TipCondition>
<Link url=”http://rapidscada.org” />
</Tip>
<Tip>
<TipCondition>
<Statuses>12, 14</Statuses>
</TipCondition>
<Html>
<p>Possible actions:</p>- Action 1
- Action 2
</Html>
</Tip>
<Tip>
<Html>
Contact your system administrator.
</Html>
</Tip>
</Tips>
</PlgNotification>October 1, 2020 at 10:09 am #7336
MikhailModerator<Statuses>612</Statuses>– you should put statuses there, not channel numbers. Look for the existing statuses in the Event types table.<ParamIDs>11</ParamIDs>– may be it’s better to set empty string inside.October 1, 2020 at 1:39 pm #7341kcks66
Thanks for your correction. I got notifications already.
Now I am getting non-stop of notification from the same input channel, what should I configure to get just one time of the alarm high event?
October 2, 2020 at 11:54 am #7343
The notifications are based on the events in the archive.
Probably, you should untick the “Event on Change” property of the input channel.October 5, 2020 at 9:21 am #7349kcks66
It is worked fine now. Thank you.
Now I am further explore the way for an user to key in their comments/remarks on the events. Is there any way for this?
October 5, 2020 at 12:03 pm #7353
Adding custom text to events requires additional development. It’s better to implement this feature in Rapid SCADA 6 in the next year. However, we can do it earlier in the version 5 according to a contract.
October 6, 2020 at 8:31 am #7358kcks66
I think I shall wait for Rapid SCADA 6 in the next year.
Thank you.July 16, 2021 at 11:55 am #9267JW
ParticipantHi Mikhail, I am trying out this module
what’s the function of <ParamIDs></ParamIDs> tag? couldn’t understand the description of this tag.
Is it possible to limit the notification to certain channels only? e.g. I have 100 channels that cloud generated events. but I only want the notification module to make sound according to 3 channels.
Is is possible to have event on status 4 changed?
July 16, 2021 at 12:47 pm #9269
tag? IDs of the quantities to show in the notification panel.
No, only the filters presented in the configuration file.
Could you explain this question?
Note: Notification plugin does not work on Linux because of Mono bug. The web app hangs.
July 16, 2021 at 1:05 pm #9272JW
ParticipantFor an event triggered by “Event on change”, the alarm message will be “Changed: #Vlaues”, this type of event won’t be in notifications.
I was just going ask about the crash on Linux server, is there any hope of fixing it or work around it?
error log of apache, for reference
[Fri Jul 16 20:42:33.128172 2021] [mpm_event:notice] [pid 4658:tid 140639949528128] AH00489: Apache/2.4.41 (Ubuntu) mod_mono/3.13 configured -- resuming normal operations [Fri Jul 16 20:42:33.128242 2021] [core:notice] [pid 4658:tid 140639949528128] AH00094: Command line: '/usr/sbin/apache2' [ERROR] FATAL UNHANDLED EXCEPTION: System.ArgumentException: The namespace '' is not defined. Parameter name: namespaceUri at System.Xml.XmlBaseWriter.GetQualifiedNamePrefix (System.String namespaceUri, System.Xml.XmlDictionaryString xNs) [0x0003c] in <f996495ece6841e5bb72faf597645519>:0 at System.Xml.XmlBaseWriter.WriteQualifiedName (System.String localName, System.String namespaceUri) [0x0004d] in <f996495ece6841e5bb72faf597645519>:0 at System.ServiceModel.Channels.MessageFault.WriteFaultCode (System.Xml.XmlDictionaryWriter writer, System.ServiceModel.EnvelopeVersion version, System.ServiceModel.FaultCode code, System.Boolean sub) [0x000d4] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.MessageFault.WriteTo (System.Xml.XmlDictionaryWriter writer, System.ServiceModel.EnvelopeVersion version) [0x0001a] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.MessageFaultBodyWriter.OnWriteBodyContents (System.Xml.XmlDictionaryWriter writer) [0x00012] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.BodyWriter.WriteBodyContents (System.Xml.XmlDictionaryWriter writer) [0x00000] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.SimpleMessage.OnWriteBodyContents (System.Xml.XmlDictionaryWriter writer) [0x00000] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.Message.WriteBodyContents (System.Xml.XmlDictionaryWriter writer) [0x0001e] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.Message.WriteBody (System.Xml.XmlDictionaryWriter writer) [0x00019] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.Message.OnWriteMessage (System.Xml.XmlDictionaryWriter writer) [0x00059] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.Message.WriteMessage (System.Xml.XmlDictionaryWriter writer) [0x00023] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.Message.WriteMessage (System.Xml.XmlWriter writer) [0x00007] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.WebMessageEncoder.WriteMessage (System.ServiceModel.Channels.Message message, System.IO.Stream stream) [0x000b1] in <5e7508d802c343d7b5ac28643e57b1dd>:0 at System.ServiceModel.Channels.Http.HttpRequestContext.InternalReply (System.ServiceModel.Channels.Message msg, System.TimeSpan timeout) [0x0003c] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.Http.HttpRequestContext.Reply (System.ServiceModel.Channels.Message msg, System.TimeSpan timeout) [0x00000] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Channels.Http.HttpRequestContext.Reply (System.ServiceModel.Channels.Message msg) [0x0000d] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Dispatcher.ListenerLoopManager.ProcessRequest (System.ServiceModel.Channels.IReplyChannel reply, System.ServiceModel.Channels.RequestContext rc) [0x0004b] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at System.ServiceModel.Dispatcher.ListenerLoopManager.TryReceiveRequestDone (System.IAsyncResult result) [0x00017] in <9513a2bb927146ddaa343ddc8a95d9c0>:0 at (wrapper managed-to-native) System.Runtime.Remoting.Messaging.AsyncResult.Invoke(System.Runtime.Remoting.Messaging.AsyncResult) at System.Runtime.Remoting.Messaging.AsyncResult.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem () [0x00000] in <533173d24dae460899d2b10975534bb0>:0 at System.Threading.ThreadPoolWorkQueue.Dispatch () [0x00074] in <533173d24dae460899d2b10975534bb0>:0 at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback () [0x00000] in <533173d24dae460899d2b10975534bb0>:0 [Fri Jul 16 20:42:40.322492 2021] [:error] [pid 4663:tid 140639836563200] (70014)End of file found: read_data failed [Fri Jul 16 20:42:40.322532 2021] [:error] [pid 4663:tid 140639836563200] Command stream corrupted, last command was 1 [Fri Jul 16 20:42:40.340810 2021] [:error] [pid 4664:tid 140639929997056] (70014)End of file found: read_data failed [Fri Jul 16 20:42:40.340854 2021] [:error] [pid 4664:tid 140639929997056] Command stream corrupted, last command was 1 [Fri Jul 16 20:42:40.340888 2021] [:error] [pid 4664:tid 140639836563200] (104)Connection reset by peer: read_data failed [Fri Jul 16 20:42:40.340922 2021] [:error] [pid 4664:tid 140639836563200] Command stream corrupted, last command was -1July 17, 2021 at 7:01 am #9275
MikhailModeratorIf you mean the crash caused by Notification Plugin, it will be fixed only in v6, because it’s something deep in the Mono framework.
