Viewing 15 posts - 286 through 300 (of 6,284 total)
  • in reply to: Is there a better way to batch modify channel attributes? #17225
    In the Administrator app, select Tools – Project Tools – Export Table. Then select an output format, and channels to export.
    in reply to: Failed to fetch. #17224
    Do the errors occur when a new table view is open, or when a table view is unloaded?
    Also please make a screenshot of the error requests in the Network tab.
    in reply to: Some channels muted in Notifications #17222
    Notification Plugin creates notification based on events that require acknowledge.
    I suggest to compare corresponding events in the bottom event panel to find differences between the events that cause notifications and other events.
    in reply to: OPC DA to OPC UA Server Question Communicator #17221
    Perhaps, you need a central Rapid SCADA instance to collect data from all PCs.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #17215
    in reply to: Failed to fetch. #17214
    To insert an image, please use a 3rd party image hosting. Maybe screenshot of the Network tab can clarify the situation.
    in reply to: Is there a better way to batch modify channel attributes? #17213
    If a table is exported to CSV, there are options to specify a channel range. If it does not work for you, provide additional information.
    in reply to: OPC DA to OPC UA Server Question Communicator #17212
    Should I only install Communicator on the OPC-DA computer?
    It’s enough to install Communicator and Agent to that computer. The Agent service is needed to upload the project and restart Communicator.
    in reply to: Failed to fetch. #17203
    Could you make screenshots of the errors in the Console and Network tabs?
    in reply to: Add Hist function in mimic-view.js #17200
    Access to historical archives is slow, so there is no plans to add those functions into the default implementation.
    You may request archives using these functions at your own risk.
    in reply to: The application is not ready…… #17199
    My knowledge of Linux, unfortunately, is not enough to answer the question of why an error occurs when the system starts:
    Unable to write data to the transport connection: Permission denied.
    Another unknown thing, why the same error does not occur for Communicator.
    What Linux version is used?
    in reply to: Add Hist function in mimic-view.js #17196
    Could you clarify the question?
    in reply to: The application is not ready…… #17195
    Error checking server connection:
    This error looks weird.
    Does Communicator have any connection issues?
    in reply to: The application is not ready…… #17194
    The Server service may start longer than the Webstation app and the Communicator service. The client applications try to connect Server while is it initializing. If they connect successfully after several attempts, it’s OK.
    in reply to: opc DA disconnection and reconnection issue #17191
    The above log file belong to the web application.
    You should find the log file of the communication line
    SCADA\ScadaComm\Log\lineXXX.log
