Viewing 15 posts - 2,131 through 2,145 (of 6,288 total)
  • in reply to: DrvDsOpcUaServer BUG #11758
    Try copying all the latest DLLs from the installation package.
    Opc.Ua.Bindings.Https is not needed for DrvDsOpcUaServer. There was a bug in OPC UA libraries that was fixed by the developers.
    in reply to: ChartPro Maximum Display Period #11757
    Yes, in Chart Pro 6 for Rapid SCADA 6 the max period can be set as a parameter.
    in reply to: hiding a channel in chartPro #11750
    Chart Pro displays trends of the selected channels.
    Do you mean to provide access rights?
    Could you explain the question?
    in reply to: Map code #11742
    If you add your function MyFunc into the Formulas table, you can use it in the channel formula: MyFunc()
    in reply to: RAPID SCADA WINDOWS FEATURES REQUIERED #11741
    Yes, you can use the both approached.
    in reply to: Using URL on inteface table #11738
    You should open a browser console by clicking F12, go to the Network tab, and check what particular web address is requested when connected remotely.
    • This reply was modified 3 years, 6 months ago by Mikhail.
    in reply to: Using URL on inteface table #11735
    Why the address contains “///” ? Probably, you should change it to http://localhost:8080/somepath to make it work.
    in reply to: RAPID SCADA WINDOWS FEATURES REQUIERED #11734
    System Requirements declares that you can install Rapid SCADA 5.8 on Windows Server 2008 R2 SP1 or later
    in reply to: Map code #11730
    Before binding the channels to a map, I suggest to display the channels on a table view to check their values.
    Please provide screenshots of the channel properties and a screenshot of a table view containing channel values.
    in reply to: RAPID SCADA WINDOWS FEATURES REQUIERED #11729
    Windows Server 2008 is not recommended, because it’s too old. However, Rapid SCADA may work on it.
    You should add a web role to the server configuration, link.
    What version of Rapid SCADA do you install?
    in reply to: Rapid SCADA 6 Beta #11726
    For small projects it may be easier to create them from scratch.
    in reply to: Rapid SCADA 6 Beta #11723
    Project converter from v5 to v6 can be found here. File name is ProjConv5to6.zip
    in reply to: Loggin server error #11722
    After installation of Rapid SCADA 5 the services are stopped. You should restart a computer to start them.
    The installer of Rapid SCADA 6 starts the services automatically.
    in reply to: Send command #11721
    If the time duration to poll a device is 5seconds
    Request timeout cannot be interrupted. Use smaller timeout if needed.
    in reply to: How to manage string data in Version 6 #11720
    For the example 3 you should create separate tags like
    – Rectifier fault
    – Inverter fault
    They should not be strings.
    The feature of working with string tags may be added in the future version of the driver. I’ve added it to the wish list.
