Loggin server error
Forum Home › Forums › Runtime Bugs › Server Bugs › Loggin server error
  • #8718
    VNPay
    Hi, I loggin server an error :” server is unavailable”
    #8724
    Check C:\SCADA\ScadaServer\Log\ScadaServerSvc.log for the error details.
    #9543
    Naseem
    I have the same issue ”server is unavailable” and did not find the log
    Please help
    #9544
    Open the services list in Windows and make sure that ScadaServerService is running.
    Also make a screenshot of the C:\SCADA\ScadaServer\Log\ folder
    #11716
    Ibou22
    I have also the same issue. I am using v5.8.4 on windows.
    Problem:
    Adminstrator Application (DemoProject) > Instances > Default > Server > Stats > Server State: File not found, Server Log: File not found.
    Ofcourse when i start the instance in the web browser, i can’t login: Server not available.
    For the directory you mentioned above C:\SCADA\ScadaServer\Log\ is empty in my case
    How can i fix this?
    P.S. I tried with the prerelease v6 and the server was working normally, but there were many other bugs so i decided to go back to the v5.8.4 (latest stable version)
    Thanks in advance!
    Ibou
    #11719
    Ibou22
    Hello again,
    Now the server is working fine.
    Reason: The windows was not running the server service.
    Solution: Press Win+R then type “services.msc”. Scroll to “ScadaServerService” and click start.
    Hope this helps!
    Ibou
    #11722
    After installation of Rapid SCADA 5 the services are stopped. You should restart a computer to start them.
    The installer of Rapid SCADA 6 starts the services automatically.
