Thank you for the update.
May be it would be more comfortable if you create separate devices (like CONTROL_2 etc.) on the same communication line. I mean if they related to different physical devices.
MikhailModeratorHello Tony,
There are no special recommendations.
Please use Microsoft docs for installing IIS on Windows server.
Every execution of the above code a client requests different data points. Probably, they don’t exists. Try specifying particular timestamp.
MikhailModeratorAlso needed screenshots of the Objects and Views tables, and operator’s interface.
When I try to edit .xml file like you said above, the new config is not added in the Administrator’s channel table after “upload configuration”.
Please provide more info what file do you edit and how.
MikhailModeratorCould you provide screenshots of the existing configuration?
MikhailModeratorDon’t forget to download the changed configuration into the project.
MikhailModeratorDear Matt,
By default the web application includes a frame with the above URL that contains a Google counter. To remove it, open the Webstation configuration and untick the “Share depersonalized stats with the developers” checkbox.
MikhailModeratorTo change web page styles, you need to update *.scss files, located in ScadaWeb\wwwroot\css, and compile them into *.min.css
MikhailModeratorRights are assigned on objects. Objects can have parents and children.
You could create a child object, set it to a channel, and assign necessary rights.
MikhailModerator@palennt, send links to your screenshots to get more detailed recommendations.
MikhailModeratorYou can read strings from OPC UA and OPC Classic. If you need to read a string, configure OPC driver and create channels using the Administrator tools. Channels for strings would be created by the wizard.
MikhailModeratorGood.
MikhailModerator1. Create custom roles in the Roles table.
2. Specify object rights.
3. Assign object for views in the Views table.
4. Set roles to users.
MikhailModeratorAlso recreate DrvDsOpcUaServer.xml if it exists.
