I have an issue with all my temperature measurements. When they drop below 0°C the go in error (max scale). PLC I am communicating with did not change, and it worked before perfectly with other SCADA server than Rapid Scada. So I think issue is in Rapid Scada.
Channel type is configured as Real.
How can I tell Rapid Scada that negative results are ok?
This topic was modified 3 years, 10 months ago by PVO.
