Please make a screenshot of the received data and provide an example what data you need to extract.
MikhailModeratorMy vision is that the solution can include a new database schema and the custom web forms built in the Webstation application as a web plugin. It requires development that is not a part of the Rapid SCADA core.
We update keys from v5 to v6 on the same machine for free.
Common license terms are also work, please check this link.
The Channels table has the particular number fields. To add new properties related to channels, I suppose, an additional database table should be added to implement customer needs.For example, you create a database schema using PostgreSQL, and develop web UI to edit it. Your data would refer Rapid SCADA channels.
Try pressing Shift + F5 or Ctrl + F5 in browser to refresh.
Open the Schemas node and check what schemas are available. You should find data there.
Thank you for the info.
MikhailModeratorRapid SCADA 6.1.6 update has been released.
– Added a new CSV reader driver that retrieves data from CSV files.
– Fixed errors.
Images are located in SCADA\ScadaWeb\wwwroot\images
You can overwrite them.
Open the Administrator application and check log files of the web application for additional details.December 8, 2023 at 11:07 am in reply to: Communicator Send only modified data of device tags setting #13805
Then you can enable PostgreSQL archives. For more details please create a new topic. This topic is about Communicator.
MikhailModeratorI plan to make and share a new converter for converting history data between.dat and.csv.
It would be great. It could be added to https://github.com/RapidScada/scada-community repository.
This reply was modified 2 years, 5 months ago by
MikhailModeratorDatToCsv.exe for v5 creates csv like https://ibb.co/QfcMW7Q
MikhailModeratorUsing Administrator v5 we can export to this csv https://ibb.co/jhTFJmR
It would be useful to be able to import such file into v6.
If channel status is 0, a cell is empty. Otherwise, let’s assume status is 1.December 7, 2023 at 10:14 am in reply to: Communicator Send only modified data of device tags setting #13792
In pgAdmin right-click the Databases node and create a new database, named rapid_scada -
