What should be the right configuration in communicator for Modbus TCP protocol?
This question is too general. Many configurations are right. One of the possible examples is included in the default configuration.
Thank you for the screenshots.
Do the data are successfully stored in your database when you use Generator?
You should describe in details what you did, what you get and what you expect.
MikhailModeratorYou should change the type of the channels to Real.
Formula was needed for the ADAM input module. May be your module doesn’t need any formulas.July 20, 2018 at 11:46 am in reply to: How to install scada on Raspberry Pi using Windows 10 IOT #4041
MikhailModeratorI recommend Raspbian of the actual version. The step by step installation manual is included in the Linux distributive of Rapid SCADA.
MikhailModerator🙂
You should check the log file of the module to find the cause.
MySQL is owned by Oracle Corporation ))
MikhailModeratorThis approach is useful to store values in the archive in the beginning of a new hour and then reset them, for example.
You can write HourBeg2() with your own logic.
MikhailModeratorThe bug is fixed and the fix will be included in the next version of Rapid SCADA in August or September.
Thank you for your help.
Where in the source code these lines are located?
July 19, 2018 at 12:41 pm in reply to: How to install scada on Raspberry Pi using Windows 10 IOT #4023
MikhailModeratorIf you have some experience with Win 10 iOT, please share your opinion.
July 19, 2018 at 12:40 pm in reply to: How to install scada on Raspberry Pi using Windows 10 IOT #4021
I suppose, the special port of Rapid SCADA should be implemented for Win 10 iOT. This is not a normal operating system, it has restricted .NET Framework and usual applications don’t work on it.
To be honest, I don’t think this is a good idea, and I don’t see the future of Win 10 iOT. May be I’m wrong.
MikhailModeratorI will check and write here.
If possible, make a file name shorter. You can edit the table structure in ScadaBase.sdf file and change the field length, but it is not recommended.
The issue is known, in a new version of a database the field will be longer. -
