MikhailModeratorYes, it’s possible. For example, you can deploy a virtual machine on Google Cloud or Azure and run Rapid SCADA on this machine. Also it’s possible to provide access to your workstation from the internet. Depends on your needs.
When you try to open AdvancedDashboard, there should be a record in ScadaServerSvc.log. Try to open the dashboard, then look in the server log.
I think Automatic Control module is necessary for this purpose. For testing, you can send commands manually from the web app.
You should check that the file in C:\SCADA\Interface\Monitoring\AdvancedDashboard.xml exists. And also check C:\SCADA\ScadaServer\Log\ScadaServerSvc.log for some useful info.
Try changing the passwords back to 12345. Then do this.
We can fix this issue remotely for a fee in case of emergency. Contact us by email if needed.
According to the icon of the AdvancedDashboard item, we can see that Dashboard Plugin is active.
Check C:\SCADA\ScadaWeb\log\ScadaWeb.log for the error details.
– explorer tree that contains views
This image is also important. I mean the screenshot of the main page of the web application.
Please also make screenshots of the web application:
– installed plugins page
MikhailModeratorGood 🙂
Please provide screenshots of your settings and web interface.
You need to download and install Extra Scheme Components.
If it is installed correctly, in Scheme Editor you will see a Gauge component.
On the screenshot there is a DynamicPicture component, but you need a Gauge component.
Administrator already has full rights. You should clear the Rights table.
November 18, 2020 at 2:31 pm in reply to: Is KPView’s AppDirs.ConfigDir different from that of KPLogic #7575
MikhailModeratorAlso KpLogic can provide a service like WCF or gRPC that is available from the KPView (from the project).
November 18, 2020 at 2:30 pm in reply to: Is KPView’s AppDirs.ConfigDir different from that of KPLogic #7574
MikhailModeratorThe project should not be changed by runtime. If you need something like that, you should write changes to
C:\SCADA\ScadaComm\Storage
C:\SCADA\ScadaServer\Storage
or to a 3rd party database and then use your data. -
