Forum Home › Forums › Uncategorized Issues › Scada Server connection problemes
- This topic has 4 replies, 2 voices, and was last updated 11 years, 10 months ago by
January 27, 2015 at 1:14 pm #58
teleco
ParticipantI have problems to connect to 127.0.0.1. However, when I text http:\\127.0.0.1 in browser bar it shows me the IIS8 initial site.
2015-01-25 18:53:57 <MANUEL><SYSTEM><ACT> ScadaServerService is started
2015-01-25 18:53:58 <MANUEL><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2015-01-25 18:53:58 <MANUEL><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2015-01-25 18:54:00 <MANUEL><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 14
2015-01-25 18:54:00 <MANUEL><SYSTEM><ACT> Ouput channels are read from the configuration database
2015-01-25 18:54:00 <MANUEL><SYSTEM><ACT> Users are read from the configuration database
2015-01-25 18:54:00 <MANUEL><SYSTEM><ACT> Formulas are read from the configuration database
2015-01-25 18:54:04 <MANUEL><SYSTEM><ACT> The formulas source code has been compiled
2015-01-25 18:54:04 <MANUEL><SYSTEM><ACT> Connection listener is started
2015-01-25 18:54:04 <MANUEL><SYSTEM><ACT> Start server
2015-01-25 18:54:04 <MANUEL><SYSTEM><ACT> Current data are not loaded
2015-01-25 18:54:13 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-25 18:54:13 <MANUEL><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2015-01-25 22:15:36 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-25 22:15:45 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-25 22:15:45 <MANUEL><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2015-01-26 10:34:26 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 10:34:27 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 10:34:28 <MANUEL><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2015-01-26 13:09:02 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 13:09:02 <MANUEL><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
2015-01-26 13:09:02 <MANUEL><SYSTEM><ACT> Check user teleco name and password. Result: failed
2015-01-26 13:10:02 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 13:39:06 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 13:39:06 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-26 13:39:06 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 13:39:28 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 13:39:28 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-26 13:39:28 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 13:39:53 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 13:39:53 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-26 13:39:53 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 13:44:26 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 13:44:26 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-26 13:44:26 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 13:45:20 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 13:45:20 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-26 13:45:20 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 13:48:11 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 13:48:11 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-26 13:48:11 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 13:48:28 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 13:48:28 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-26 13:48:28 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-26 14:02:01 <MANUEL><SYSTEM><ACT> Connect to client 192.168.56.1
2015-01-26 14:02:01 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-26 14:02:01 <MANUEL><SYSTEM><ACT> Disconnect client 192.168.56.1
2015-01-26 14:02:36 <MANUEL><SYSTEM><ACT> Connection listener is stopped
2015-01-26 14:02:36 <MANUEL><SYSTEM><ACT> Server is stopped
2015-01-26 14:02:36 <MANUEL><SYSTEM><ACT> ScadaServerService is stopped
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> ScadaServerService is started
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 14
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> Ouput channels are read from the configuration database
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> Users are read from the configuration database
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> Formulas are read from the configuration database
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> The formulas source code has been compiled
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> Connection listener is started
2015-01-26 14:02:37 <MANUEL><SYSTEM><ACT> Start server
2015-01-26 14:02:38 <MANUEL><SYSTEM><ACT> Current data are loaded
2015-01-26 14:02:38 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 14:02:38 <MANUEL><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2015-01-26 14:05:05 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 14:05:10 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:05:15 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:05:15 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 14:05:20 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:05:25 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:05:25 <MANUEL><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2015-01-26 14:05:25 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 14:05:35 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 14:05:40 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:05:40 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 14:05:40 <MANUEL><SYSTEM><EXC> Error communicating with the client 127.0.0.1: Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host.
2015-01-26 14:05:48 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 14:05:53 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:05:58 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:06:03 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:06:08 <MANUEL><SYSTEM><ERR> Incorrect format of the data received from the client 127.0.0.1
2015-01-26 14:06:08 <MANUEL><SYSTEM><ACT> Connection listener is stopped
2015-01-26 14:06:08 <MANUEL><SYSTEM><ACT> Server is stopped
2015-01-26 14:06:08 <MANUEL><SYSTEM><ACT> ScadaServerService is stopped
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> ScadaServerService is started
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 14
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Ouput channels are read from the configuration database
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Users are read from the configuration database
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Formulas are read from the configuration database
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> The formulas source code has been compiled
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Connection listener is started
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Start server
2015-01-26 14:06:10 <MANUEL><SYSTEM><ACT> Current data are loaded
2015-01-26 14:06:18 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-26 14:06:18 <MANUEL><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2015-01-27 12:25:17 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 12:25:20 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 12:25:20 <MANUEL><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2015-01-27 13:36:31 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:36:31 <MANUEL><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2015-01-27 13:37:31 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:56:42 <MANUEL><SYSTEM><ACT> Connection listener is stopped
2015-01-27 13:56:42 <MANUEL><SYSTEM><ACT> Server is stopped
2015-01-27 13:56:42 <MANUEL><SYSTEM><ACT> ScadaServerService is stopped
2015-01-27 13:56:43 <MANUEL><SYSTEM><ACT> ScadaServerService is started
2015-01-27 13:56:43 <MANUEL><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2015-01-27 13:56:43 <MANUEL><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2015-01-27 13:56:43 <MANUEL><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 14
2015-01-27 13:56:43 <MANUEL><SYSTEM><ACT> Ouput channels are read from the configuration database
2015-01-27 13:56:43 <MANUEL><SYSTEM><ACT> Users are read from the configuration database
2015-01-27 13:56:43 <MANUEL><SYSTEM><ACT> Formulas are read from the configuration database
2015-01-27 13:56:44 <MANUEL><SYSTEM><ACT> The formulas source code has been compiled
2015-01-27 13:56:44 <MANUEL><SYSTEM><ACT> Connection listener is started
2015-01-27 13:56:44 <MANUEL><SYSTEM><ACT> Start server
2015-01-27 13:56:45 <MANUEL><SYSTEM><ACT> Current data are loaded
2015-01-27 13:56:52 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:56:52 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:56:52 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:57:02 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:57:02 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:57:02 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:57:12 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:57:12 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:57:12 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:57:22 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:57:22 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:57:22 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:57:33 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:57:33 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:57:33 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:57:43 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:57:43 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:57:43 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:57:53 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:57:53 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:57:53 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:58:03 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:58:03 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:58:03 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:58:13 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:58:13 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:58:13 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:58:23 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:58:23 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:58:23 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:58:33 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:58:33 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:58:33 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:58:43 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:58:43 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:58:43 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:58:53 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:58:53 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:58:53 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:59:03 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:59:03 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:59:03 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:59:09 <MANUEL><SYSTEM><ACT> Connection listener is stopped
2015-01-27 13:59:09 <MANUEL><SYSTEM><ACT> Server is stopped
2015-01-27 13:59:09 <MANUEL><SYSTEM><ACT> ScadaServerService is stopped
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> ScadaServerService is started
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 14
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Ouput channels are read from the configuration database
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Users are read from the configuration database
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Formulas are read from the configuration database
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> The formulas source code has been compiled
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Connection listener is started
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Start server
2015-01-27 13:59:10 <MANUEL><SYSTEM><ACT> Current data are loaded
2015-01-27 13:59:13 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:59:13 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:59:13 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:59:31 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:59:31 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:59:31 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:59:41 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:59:41 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:59:41 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 13:59:51 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 13:59:52 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 13:59:52 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:00:02 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:00:02 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:00:02 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:00:12 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:00:12 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:00:12 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:00:22 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:00:22 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:00:22 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:00:32 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:00:32 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:00:32 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:00:42 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:00:42 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:00:42 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:00:52 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:00:52 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:00:52 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:01:02 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:01:02 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:01:02 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:01:12 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:01:12 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:01:12 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:01:22 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:01:22 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:01:22 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:01:32 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:01:32 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:01:32 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:01:43 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:01:43 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:01:43 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:01:53 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:01:53 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:01:53 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:02:03 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:02:03 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:02:03 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:02:13 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:02:13 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:02:13 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:02:23 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:02:23 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:02:23 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:02:33 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:02:33 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:02:33 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:02:43 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:02:43 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:02:43 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:02:53 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:02:53 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:02:53 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:02:59 <MANUEL><SYSTEM><ACT> Connection listener is stopped
2015-01-27 14:02:59 <MANUEL><SYSTEM><ACT> Server is stopped
2015-01-27 14:02:59 <MANUEL><SYSTEM><ACT> ScadaServerService is stopped
2015-01-27 14:02:59 <MANUEL><SYSTEM><ACT> ScadaServerService is started
2015-01-27 14:02:59 <MANUEL><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2015-01-27 14:02:59 <MANUEL><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2015-01-27 14:02:59 <MANUEL><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 14
2015-01-27 14:03:00 <MANUEL><SYSTEM><ACT> Ouput channels are read from the configuration database
2015-01-27 14:03:00 <MANUEL><SYSTEM><ACT> Users are read from the configuration database
2015-01-27 14:03:00 <MANUEL><SYSTEM><ACT> Formulas are read from the configuration database
2015-01-27 14:03:00 <MANUEL><SYSTEM><ACT> The formulas source code has been compiled
2015-01-27 14:03:00 <MANUEL><SYSTEM><ACT> Connection listener is started
2015-01-27 14:03:00 <MANUEL><SYSTEM><ACT> Start server
2015-01-27 14:03:00 <MANUEL><SYSTEM><ACT> Current data are loaded
2015-01-27 14:03:03 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:03:03 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:03:03 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:03:13 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:03:13 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:03:13 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:03:24 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:03:24 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:03:24 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:03:34 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:03:34 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:03:34 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:03:44 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:03:44 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:03:44 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:03:54 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:03:54 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:03:54 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:04:04 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:04:04 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:04:04 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:04:14 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:04:14 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:04:14 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:04:18 <MANUEL><SYSTEM><ACT> Connection listener is stopped
2015-01-27 14:04:18 <MANUEL><SYSTEM><ACT> Server is stopped
2015-01-27 14:04:18 <MANUEL><SYSTEM><ACT> ScadaServerService is stopped
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> ScadaServerService is started
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 14
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Ouput channels are read from the configuration database
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Users are read from the configuration database
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Formulas are read from the configuration database
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> The formulas source code has been compiled
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Connection listener is started
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Start server
2015-01-27 14:04:19 <MANUEL><SYSTEM><ACT> Current data are loaded
2015-01-27 14:04:24 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:04:24 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:04:24 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:04:34 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:04:34 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:04:34 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:04:44 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:04:44 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:04:44 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:04:54 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:04:54 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:04:54 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:05:04 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:05:04 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:05:04 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:05:15 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:05:15 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:05:15 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:05:16 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:05:16 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-27 14:05:16 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:05:25 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:05:25 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:05:25 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:05:33 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:05:33 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user teleco
2015-01-27 14:05:33 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:05:35 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:05:35 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:05:35 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:05:45 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:05:45 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:05:45 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:05:55 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:05:55 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:05:55 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:06:05 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:06:05 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:06:05 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:06:15 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:06:15 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:06:15 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:06:25 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:06:25 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:06:25 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:06:35 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:06:35 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:06:35 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:06:45 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:06:45 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:06:45 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:06:55 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:06:55 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:06:55 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:07:06 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:07:06 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:07:06 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:07:16 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:07:16 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:07:16 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:07:26 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:07:26 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:07:26 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:07:36 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:07:36 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:07:36 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:07:46 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:07:46 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:07:46 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:07:56 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:07:56 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:07:56 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:08:06 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:08:06 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:08:06 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:08:16 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:08:16 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:08:16 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:08:26 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:08:26 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:08:26 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:08:36 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:08:36 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:08:36 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:08:46 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:08:46 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:08:47 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:08:57 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:08:57 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:08:57 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:09:07 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:09:07 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:09:07 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:09:17 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:09:17 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:09:17 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:09:27 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:09:27 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:09:27 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:09:37 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:09:37 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:09:37 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:09:45 <MANUEL><SYSTEM><ACT> Connection listener is stopped
2015-01-27 14:09:45 <MANUEL><SYSTEM><ACT> Server is stopped
2015-01-27 14:09:45 <MANUEL><SYSTEM><ACT> ScadaServerService is stopped
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> ScadaServerService is started
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 14
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Ouput channels are read from the configuration database
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Users are read from the configuration database
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Formulas are read from the configuration database
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> The formulas source code has been compiled
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Connection listener is started
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Start server
2015-01-27 14:09:46 <MANUEL><SYSTEM><ACT> Current data are loaded
2015-01-27 14:09:47 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:09:47 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:09:47 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:09:57 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:09:57 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:09:57 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:10:07 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:10:07 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:10:07 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1
2015-01-27 14:10:17 <MANUEL><SYSTEM><ACT> Connect to client 127.0.0.1
2015-01-27 14:10:17 <MANUEL><SYSTEM><ACT> Unsuccessful attempt to authenticate the user ScadaComm
2015-01-27 14:10:17 <MANUEL><SYSTEM><ACT> Disconnect client 127.0.0.1January 28, 2015 at 6:53 pm #59
Did this issue appear just after the installation of Rapid SCADA or after configuring?
If you make some changes using SCADA-Administrator before the problem occurs please describe them.“http:\\127.0.0.1 in browser bar it shows me the IIS8 initial site” – it’s OK.
This reply was modified 11 years, 10 months ago by
January 28, 2015 at 7:31 pm #61
MikhailModeratorI think you should restore User table in the configuration database. Do the following:
1. Open SCADA-Administrator and make a backup of the configuration database.
2. Clear all the data from Users table.
3. Unzip user.dat from ScadaAdmin.zip of the installation packege and overwrite the existing file.
4. Import user.dat into the configuration database.
5. Restart SCADA-Server.Open http://localhost/scada and try to connect as: admin
Default password: 12345January 29, 2015 at 11:25 am #63teleco
ParticipantThank you very much Mikhail for solving my problem, now I can connect to the server and see the control center in my web browser. But still, I would like to know how to change passwords and user names, in order to make the connections… I thought that it is in Scada Administrator, in the Users template, is it?
On more question, once I have logged to some account, when I try to visualize the default scheme, the next error appears:
WCF service error: [HttpWebRequest_WebEXception_RemoteServer]
Argumentos: NotFound
Las cadenas de recursos de depuración no están disponibles. La clave y los argumentos suelen proporcionar suficiente…January 29, 2015 at 2:09 pm #66
MikhailModeratorOf course you can add new users and modify the existing.
Try to do a one modification and if the system works strangely post a question to Understanding section with description of changes and symptoms.Could you make a separate topic about WCF service error?
