Acces the Modbus data from outside the LAN
Forum Home › Forums › Understanding the Software › Acces the Modbus data from outside the LAN
  • #7604
    anne
    Is it possible to upload the localhost/Scada/View page to a server?
    So that I can acces that page from anywhere using e.g. ‘ mywebpage.com/scada’ to view the data and use the scheme views to make adjustments.
    • This topic was modified 5 years, 12 months ago by Mikhail.
    #7606
    Yes, it’s possible. For example, you can deploy a virtual machine on Google Cloud or Azure and run Rapid SCADA on this machine. Also it’s possible to provide access to your workstation from the internet. Depends on your needs.
    #7653
    anne
    I don’t want to use a virual machine, I need a website page which I can access from any device connected to the internet, to access the data. In the deployment profile you can adjust the webstation URL, is that where you can put a website to where the Scada View can be uploaded?
    #7656
    If you need to access your office or home network from the internet, you need static IP address or dynamic DNS like https://www.noip.com/
    It just opens the specified URL. Doesn’t affect the real web site.
    #7657
    And you need configure a router to forward the incoming requests to your Rapid SCADA server.
