I recommend to update the file structure on disk as you need to show in the tree
Root SiteA NewFile.schIn the title column just enter simple titles.
You can also set Title = Root\SiteA\Option1 but it’s not clear when not reflects file structure.
MikhailModeratorIs it possible to use formulas for input channels that are using MQTT?
Formulas are processed on the Server application level and they do not depend on a driver.
The result of formulas can be displayed by views, not in Communicator.
That’s mean i can not configure the device that can send email to group_name.7
It duplicates another topic.
Please try the updated version of the driver.
In case of similar error, it can write more info in the log that helps to find the cause.
Try selecting a command node in the tree. If it doesn’t help, provide links to screenshots.
MikhailModeratorPlease contact us by email.
DB export module executes only 1 request per operation. If you need to execute many requests, wrap them by stored procedure on the DB side.
MikhailModeratorShare the results please.
MikhailModeratorIt’s possible to generate XML as specified above in Excel.
MikhailModeratorThe described behavior is programmed. Probably, it should be configurable in the communication layer properties.
MikhailModeratorLikely, 2810 signals is caused by data length overflow. You should try 4500 signals.
MikhailModeratorAfter a polling session is finished, Communicator sends data to the Server app. It sends data device by device. Usually it sends only modified data (it depends on the configuration). So when you split devices, it sends data correctly.
However, the limit of 2810 signals should not be the maximum. I expect that the max. is 4680 according to the binary protocol between Communicator and Server.
Could you check if there are any errors in Communicator and Server log files?
MikhailModeratorFor Modbus salve in Linux VM, you will need to change port number to larger than 1024, e.g. 1502.
Are there any limits on port number?
Most often, computer code changes when a set of MAC addresses of the PC changes. If a license key is bound to a MAC address that is still presented, key continues be valid.
MikhailModeratorThank you for asking. It indicates that this feature is needed for the users.
