how to call Opc ua method?
Forum Home › Forums › Communicating with Devices › how to call Opc ua method?
  • #8811
    JordanShawn
    Hi there!
    I’m using KpOpcUa to communicate with siemens cnc opc ua server.
    I added a new deivce and selected “opc ua” as its type.
    Now I could add a variable node successfully. However,It seems not possible to assigned a “method” type node as a command.
    Is there any way to call a method of opc ua server through rapidscada?
    #8812
    Method calls currently not supported. Probably, they will be added in the future.
    If you need this feature on time, we could implement it according to a contract.
    #8813
    Thank you for asking. It indicates that this feature is needed for the users.
