Automatic Control Module command disabled
Forum Home › Forums › Installation Issues › Automatic Control Module command disabled
  • #8838
    ptrenta
    i want to try to send a command at certai hour of each day.
    I have installed rapidScada 5.8.1 and installed the module Automatic Control 5.2.5.1.
    Once activated with test key, i try to add a time trigger and i can set the name and the raise time but all command parameters are disabled.
    The command are disabled for each trigger i try to add.
    is there something i should do?
    Thanks a lot.
    Paolo
    #8839
    Try selecting a command node in the tree. If it doesn’t help, provide links to screenshots.
    #8879
    ptrenta
    Right, it works. Thanks a lot
