By default, the module exports data when it comes from Communicator to Server. Calculated channels not included in this case.
To export all data, including calculated channels, you can use the archive upload feature of the module.July 4, 2022 at 9:32 am in reply to: How to set the number after the comma to 2 digits (Elastic Report)? #10400
MikhailModeratorI guess, that the issue is related to Excel format. In the channel properties there are no decimals, but in the cell there are a lot of digits after decimal separator.
For Rapid SCADA 5, the above is correct.
In version 6, the auto login feature is built-in the web app. It is applied for any IP. So in Rapid SCADA 6, you can’t use auto login only for local connections. In this case, you could use simple “Remember me” locally.July 1, 2022 at 1:02 pm in reply to: How to set the number after the comma to 2 digits (Elastic Report)? #10395
MikhailModeratorThe plugin version is up to date.
Does the error appears on PDF and HTML formats?June 30, 2022 at 9:24 am in reply to: How to set the number after the comma to 2 digits (Elastic Report)? #10392
Thank you for the screenshots. The settings seem OK.
What version of Elastic Report is in use? It is displayed by the Webstation app on the plugins page.
What output format do you use, HTML, PDF or Excel?
MikhailModeratorIf you need help while implement such formula, ask.
The general idea is using the channel of the Calculated real type which is calculated every iteration.
In the formula you should check the time difference with the previous calculation.
If the difference >= 1 second, do the required calculations.
MikhailModeratorThank you for the description. Your software is interesting!
A file *.sch should be loaded to get max component ID. However, you should load it anyway to append new components.June 26, 2022 at 8:49 am in reply to: How to set the number after the comma to 2 digits (Elastic Report)? #10385
MikhailModeratorCould you publish a screenshot of the channel 9405 properties?
What output format do you use, HTML, PDF or Excel?-
This reply was modified 3 years, 12 months ago by
June 24, 2022 at 3:09 pm in reply to: How to set the number after the comma to 2 digits (Elastic Report)? #10381
It uses format of the input channel. Check that it is set.
MikhailModeratorThere is a magic command that I use sometimes to fix SSL issues:
sudo apt-get install --reinstall ca-certificates
MikhailModeratorLet’s close this topic.
OK.
The issue is weird. In version 6 we’ve made uploading configuration more clear, and I expect that such problem will not appear.
MikhailModeratorAlternatively, consider sending notifications by Telegram messenger.
MikhailModerator
Could you explain your question? -
