Skip to content
Rapid SCADA Forum
Technical support of Rapid SCADA users
  • Forum Home
  • Rapid SCADA
  • Contact
Is that possible autologin just for localhost?
Forum Home › Forums › New Ideas › Is that possible autologin just for localhost?
  • This topic has 8 replies, 5 voices, and was last updated 3 years, 9 months ago by Mikhail.
  • July 3, 2022 at 4:14 pm #10396
    GokhanCi
    July 4, 2022 at 12:25 am #10398
    Merdock
    Here some threads about autologin. Perhaps in version 5. You only need to configure the Autologin.aspx as local access.3
    https://forum.rapidscada.org/?action=bbp-search-request&bbp_search=Autologin
    July 4, 2022 at 9:26 am #10399
    For Rapid SCADA 5, the above is correct.
    In version 6, the auto login feature is built-in the web app. It is applied for any IP. So in Rapid SCADA 6, you can’t use auto login only for local connections. In this case, you could use simple “Remember me” locally.
    November 15, 2022 at 12:05 pm #11531
    cooldjmc
    Hi, how can I configure the Autologin.aspx as local access.3 ?
    November 15, 2022 at 1:48 pm #11534
    Could you explain in details?
    November 16, 2022 at 4:08 am #11547
    zzz
    You could however just enable v6 autologin, and use nginx‘s access-control rules to restrict RSv6 access to desired ip range.
    Note nginx’s access-control is applied before requests hit RS. You won’t be able to access RS’s web port from these restricted ip either, let alone login.
    November 16, 2022 at 2:20 pm #11558
    cooldjmc
    Hi i just need that autologin can be possible only from localhost(it is a linux instance) so when I access scada from network you must enter user and passowrd.
    My question comes after i read posts 10398 an 10399. How to configure Autologin.aspx as local access only.
    I will consider to update to V6 after a stable build, and not shure if modules permanent key purchased are valid for V6.
    Thanks,
    November 17, 2022 at 2:19 pm #11569
    Probably you should deploy 2 instances of Webstation with different settings.
    November 17, 2022 at 2:19 pm #11570
    We upgrade keys manually for free for the same machine.
Log In
Log In
Register Lost Password
Search Forums
Forum Statistics
Registered Users
822
Forums
18
Topics
2,295
Replies
13,242
Topic Tags
1,111
Empty Topic Tags
297
Recent Topics
  • Communication error and reconnection
  • New release Rapid SCADA 6.5.x
  • ScadaAdminWebJP
  • Modbus Register 32 byte length
  • Cleaning mod_arc_postgre_sql
Copyright © 2025 Rapid SCADA
