MikhailModeratorTo display only current data, use schemes instead of table views.
MikhailModeratorHello Christian,
Right. When you configure device in Communicator, don’t forget to set tag codes.
MikhailModeratorUse the step by step installation instructions. If you have an error on some step, share a screenshot.
MikhailModeratorI can check the screenshot if you make the link public.
MikhailModeratorTo communicate with a Modbus device you need a Modbus driver that is included in Rapid SCADA by default. While Modbus Slave driver is used in special rare cases.
MikhailModeratorTo activate Chart Pro you should use a way described in the manual. In case of application errors, check application log files.
MikhailModeratorComputer code can be found in the communication line log on Communicator start after you configure the driver and upload the project.
MikhailModeratorEnter an IP address into the Call Number field, and Modbus ID into the Address field.
MikhailModeratorPlease provide a screenshot of the error.
MikhailModeratorYou should publish a plugin project to a folder using Visual Studio.
Then download the plugin executables to check which files are needed.
Copy your files into the Web app installation directory.
MikhailModeratorCheck this topic.
MikhailModeratorChannel is similar to a variable that stores a tag value.
Use this article as a step by step guide to configure polling of a Modbus device.
MikhailModeratorTo display only current data, use scheme views and dashboards.
MikhailModeratorA reports take data from a historical archive. This demo demonstrates how reports work.
Modules are installed according to their manuals.
MikhailModerator -
