built and install openplugin
Forum Home › Forums › Installation Issues › built and install openplugin
  • #10537
    291348113
    thank you for your work ,i download your code from github and built the openplugin, and how can i install openplugin and put it into use? Now ,i put it in plugin of scadaweb and coudn’t find it in admin or the host web,thank you
    #10538
    You should publish a plugin project to a folder using Visual Studio.
    Then download the plugin executables to check which files are needed.
    Copy your files into the Web app installation directory.
