Viewing 15 posts - 2,311 through 2,325 (of 6,287 total)
  • in reply to: XML Content Translator for SCADA 6 #11218
    Xml Content Translator may be quite useful to create automatic translations to many languages.
    What are the differences between source and modified Xml Content Translator?
    Do you know if this app uses external or internal engine for translation?
    Is it possible to translate, for example, ScadaWeb.en-GB.xml by a few clicks?
    in reply to: Retain Variable #11217
    Please provide screenshots that illustrate the question.
    in reply to: Event Description #11216
    If Server is not available, check the log file of the Server service.
    in reply to: Notification plug in (trial key vs paid registration key) #11215
    there is no acknowledgement sound alert when the status of the defined registered is changed
    Press F12 to check browser error messages in the console.
    in reply to: Notification plug in (trial key vs paid registration key) #11214
    Permanent and trial keys work similar. If some function does not work as expected, it is not caused by using trial key.
    in reply to: Menu order of Interface #11213
    The described issue is fixed in Rapid SCADA 6.
    In version 5, as a workaround you could locate a home scheme in the subfolder.
    in reply to: Server is unavailable Error #11212
    You can check application log files via the Administrator app.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11192
    That is really interesting. Thanks a lot!
    I will try to build Rapid SCADA using your description. I will write about my experience in this topic.
    If you decided to make a guide with screenshots as a Word, Libre Office or Google document, it may be useful to save information.
    in reply to: API to access server comm line device status #11191
    Could you provide more details how you’d like to see it?
    in reply to: Long loading times of schemes #11190
    I confirm that sometimes the described issue happens. Likely it is caused, when data request has no response from server. We will fix this issue when start redesign of schemes in the next generation of scheme engine.
    in reply to: Rapid SCADA 6 Beta #11189
    If a post contains a lot of hyperlink, it can be automatically blocked by the forum protection system. Sometimes, it’s more handy to provide a one link to Google document for example.
    I found and accepted your post.
    in reply to: Web API, REST API, version 6 #11188
    Now I can access SCADA API from Node-RED easily.
    Cool!
    in reply to: Rapid SCADA 6 Beta #11176
    @123abc56, deadband logic is updated and will be included in the next release.
    in reply to: API to access server comm line device status #11174
    Yes.
    Add an extra channel for a device, set its TagCode to Status and Format to Device status.
    in reply to: More ‘native’ scheme editor #11172
    A web app seems like the better option due to being cross-platform. However, implementation of property editor is tricky.
    • This reply was modified 3 years, 8 months ago by Mikhail.
