Server is unavailable Error Forum Home › Forums › Understanding the Software › Server is unavailable Error Tagged: Server is unavailable This topic has 3 replies, 3 voices, and was last updated 3 years, 10 months ago by victorlam. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts October 9, 2022 at 3:24 am #11198 victorlamParticipant Hello, May I know where i can check the error originated from after the upload of the configuration program or file? Where is the log record file for the debugging? October 9, 2022 at 5:03 am #11199 kumajayaParticipant Administrator server stats will inform you about server status. October 10, 2022 at 1:33 pm #11212 MikhailModerator Hello, You can check application log files via the Administrator app. October 22, 2022 at 10:01 am #11343 victorlamParticipant Hello, Thanks! Yes, the best solution is to check the log file and see the problem originated from. The issue was from the formula with syntax error. Small capital letter, bracket error, … Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
