Tag number is the synonym of the Signal field in the 5th version.
Tag code is similar to tag number, but it can contain any string.Data type of the channel determines how channel data are stored. The empty cell means Double.
When you send a custom command, the driver sends data that is specified for the command.
MikhailModeratorThere is a DB Export module that can write data to MSSQL.
We don’t have a plan to develop MSSQL archive (similar to ModArcPostgreSql, for example). It can be done by other developers, or we can implement MSSQL archive by a contract.
MikhailModeratorDear Han,
Rapid SCADA includes a driver KpSms.dll that supports AT command set for sending SMS. To answer if a certain module works with the driver or not, you should test them together.
MikhailModeratorThank you. The drivers will be included in the next release.
Can the team help to prepare the video support if we can learn to use the new version V6 in a faster way?
I suggest creating a demo project to learn the v6 faster. If something is not clear, ask on the forum.
May I know where is the configuration and plug in the Webstation now?
Webstation is configured using the Administrator application.
Documentation will be added after porting the modules.
What version of Rapid SCADA do you use, 5 or 6?
I tried with the example and don’t work
Could you provide screenshots that contain actual results?
MikhailModeratorThe MQTTnet dependency has been updated. The developers of that library did significant changes. I tested it briefly. Could you build and try the updated drivers?
There is the commit link.-
This reply was modified 3 years, 5 months ago by
Web pages should be locate not inside the project, but inside the web app itself. See this example.
Good temporary solution.
MikhailModeratorSorry, I checked the manual https://rapidscada.net/docs/en/5.8/modules/plg-dashboard and found that you can specify chart configuration file for v5 also. Please choose a method that is more comfortable for you: specify axes in the single file or create many files. Or combine the both methods.
Thank you for the photo.Chart Pro for version 5 has a single configuration file. To set different colors for different quantities, you can define new YAxis with the specified Quantity ID in PlgChartPro.xml.
Chart Pro for Rapid SCADA 6 may have multiple configuration files. You can use the above method, or create different configuration files and specify them for dashboard. But, for now Dashboard Plugin for version 6 does not exist. So I wrote the 2nd method for the future use.
I’ve added the dependency upgrade to the task list. -
