Web Page View
Forum Home Forums Understanding the Software Web Page View
  • #11833
    quintelosky
    Hi
    I’m trying to add a web page (associated a popup and a id view) in my scada but don’t work. I don’t know the problem
    https://ibb.co/yPpxWs4
    https://ibb.co/n6185qy
    https://ibb.co/vVBR97k
    https://ibb.co/993S03Y
    #11835
    Web pages should be locate not inside the project, but inside the web app itself. See this example.
    #11838
    quintelosky
    Hi
    Ok, I tried with the example and don’t work
    https://ibb.co/B6vPvky
    I copied and pasted the same (you can view the path in the image), put in popup->viewid 12 and nothing. I tried with all paths combinations but don’t work. The project is in other path, like c:\scada\projects, and the rapidscada is in c:\program files\
    Can you do a simple test with your rapidscada?
    #11840
    What version of Rapid SCADA do you use, 5 or 6?
    Could you provide screenshots that contain actual results?
    #11875
    quintelosky
    Hi
    Rapid 6
    Screenshot: https://ibb.co/B6vPvky
    #11882
    The example is for v5. It does not work with v6.
    Use the appropriate web page for v6.
    Open browser tool by pressing F12 and check the actual page URL.
