Edit popup size Forum Home › Forums › Understanding the Software › Edit popup size This topic has 4 replies, 2 voices, and was last updated 3 years, 9 months ago by Mikhail. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts December 27, 2022 at 7:30 pm #11817 quinteloskyParticipant Hi everybody Can be changed width size pop up? Because ‘large’ option is small with bigger monitors Can I put a width value? Thanks This topic was modified 3 years, 9 months ago by Mikhail. December 28, 2022 at 10:06 am #11823 MikhailModerator Hi, There is no particular size option because this is how Bootstrap popups work. Do you use Rapid SCADA 5 or 6? What screen resolution? December 28, 2022 at 11:20 am #11831 quinteloskyParticipant Hi I use rapid 6. For example 1200×700 I readed that bootstrap have Extra large size, Is it possible (activate this option in rapid 6)? Thanks December 28, 2022 at 11:44 am #11832 quinteloskyParticipant Hi Ok, I edited modal.js to make tests and I can change to extra large, but the scheme compiler only accept small, normal and large Well, I modified modal.js and I’m using small to extra large (if you put small popup, you will view extra large popup) December 29, 2022 at 9:43 am #11834 MikhailModerator Hi, Good temporary solution. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
