Viewing 15 posts - 2,011 through 2,025 (of 6,279 total)
  • in reply to: Zoom icons in Chartpro plug-in #12031
    This is not an image, but a font symbol.
    Could you provide a screenshot?
    in reply to: Double vs Int #12030
    The default data type for channels is double. This data type allows to store either integers or floats. Channel formulas should return double because channels are stored as doubles.
    I recommend, not to use channel data type in the Channels table if you don’t have significant reasons to do that. Channel data type must match a tag data type provided by a device driver, which is double in most cases.
    in reply to: Required to write a formula for a command #12029
    Because the Double data type allow sto use fractional part of a number.
    in reply to: Migrate data from 5.x to 6.X #12028
    1. Could you provide a screenshot?
    2. SNMP driver has been ported to v6 recently and will be included in the next release.
    in reply to: ScadaClient.GetSlice #12020
    Could you clarify the question?
    in reply to: Remote Communicator Error #12019
    In what moment did you get that error?
    You should install Agent on computer 2 to be able to upload configuration to it using the Administrator app.
    in reply to: Disable Automatic Control Module v5 #12018
    To cancel a command, an output channel formula should return double.NaN or null, depending on the required conditions.
    Button component can be bound to an input channel that allows to hide or disable a button. But the same command can be sent from another table view, for example.
    in reply to: Map: Links #12012
    What’s the difference between plugins’ Personal and Business license?
    The answer is here.
    in reply to: Migrate data from 5.x to 6.X #12011
    Hi!
    Please check this topic. In case of questions, ask there.
    in reply to: config fie upload #12007
    in reply to: Map: Links #12006
    May be you need a kiosk mode of the browser.
    in reply to: Map: Links #12005
    Such behavior depends on a browser. In Chrome, if you start full screen mode by pressing F11, it does not exit on page navigation.
    in reply to: config fie upload #12002
    Open Config/ScadaInstanceConfig.xml for editing. Set ActiveStorage to PostgreSqlStorage, and restart Rapid SCADA services.
    in reply to: SMS GSM Cinterion Modem #12000
    According to the log, the modem does not respond: Receive: no data
    You could compare with the previous logs.
    Check connection settings.
    • This reply was modified 3 years, 4 months ago by Mikhail.
    in reply to: V6 – Extra Scheme Components #11996
