Viewing 15 posts - 1,711 through 1,725 (of 6,266 total)
  • in reply to: Problem with data adquisition #12771
    You need a channel of the Output type. Command code must match with the module. If you provide screenshots of the settings and sending command, I could check.
    in reply to: VB script #12765
    You can run *.bat or *.sh from formulas. For example:
    Process.Start(@"C:\1.bat");
    in reply to: Epoch time to Time date convert #12764
    Also possible
    dateTime = DateTimeOffset.FromUnixTimeSeconds((long)unixTimeStamp).ToUniversalTime();
    in reply to: OPC Ua error #12763
    Thank you for the update.
    Note that DrvOpcUa.View.xml affects user interface. DrvOpcUa.Logic.xml affects how the driver works.
    in reply to: Epoch time to Time date convert #12756
    @emhatek
    , what version of Rapid SCADA do you use?
    in reply to: Help, command send now in Scheme Editor #12755
    But when I set command as Send Command instead of Send Command Now, it does its job.
    Could you compare the messages in ScadaServer.log in the both cases and provide screenshots?
    in reply to: MQTT how to filter topic? #12746
    First of all, I would log some message if data.type == "report" to check whether that section is executed.
    in reply to: Installation 6.1.2 in Raspberry Pi #12745
    You could try installing .NET6 manually as written here.
    in reply to: Open new window #12737
    When a window is opened in a new tab, a browser decides whether to use a tab or separate window. You should check browser settings.
    When a window is opened in a popup, it is specified by SCADA. To change it, you can edit JavaScript files, however, it’s not recommended.
    in reply to: Problem with data adquisition #12736
    You can send a string command like
    cmd=ExportArchive
    startDT=2022-12-23 10:00:00
    endDT=2022-12-23 11:00:00
    to export historical data.
    When DB Export module receives such command, it executes the historical data queries that exist in the module configuration.
    in reply to: MQTT how to filter topic? #12735
    In such situation, using JS is the right method. If it doesn’t work, provide more info.
    in reply to: Help, command send now in Scheme Editor #12730
    If you simply need to change command value, you can set a formula of the output channel to 1, for example.
    Do you have an input channel that changes according to a command?
    in reply to: Connect two pc with RapidGate #12729
    ModRapidGate.xml and ModRapidGate_Reg.xml are created automatically in the proper location of the project when you configure the module using the Administrator application.
    in reply to: OPC DA to UA Gateway #12724
    I guess, OPC server should have an option that allows to restrict publishing speed. Or may be, it’s a client subscription includes such parameter. For example, Rapid SCADA OPC UA client subscription have the Publishing interval option.
    in reply to: OPC DA to UA Gateway #12723
    If your project requires work with a large amount of incoming data, we can take part in it to improve existing Rapid SCADA modules.
    Alternatively, if you are a software developer, you can join the development and submit a solution.
    Just for info: PostgreSQL archives (ModArcPostgreSql.dll) appends all data points in the queue. And it’s easy to monitor the queue size and data insert rate.
