Installation 6.1.2 in Raspberry Pi
Forum Home › Forums › Installation Issues › Installation 6.1.2 in Raspberry Pi
  • #12743
    ArunRuchir
    I have installed Dotnet in Raspberry Pi 4 as per all instructions. Then installed the latest version of RapidScada 6.1.2
    Unfortunately, dotnet is not working.
    $ echo $PATH
    /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/share/dotnet
    $ dotnet -version
    -bash: /usr/bin/dotnet: No such file or directory
    Because of this error, none of the services are working and I am not able to proceed.
    Can someone please help?
    #12745
    You could try installing .NET6 manually as written here.
    #12747
    curl -sSL https://dot.net/v1/dotnet-install.sh | sudo bash /dev/stdin --channel LTS --runtime aspnetcore --install-dir /usr/share/dotnet/
    Try to install via a script from Microsoft
    Add a path as needed
    export PATH=”$PATH:/usr/share/dotnet”
    or a link as in the RapidScada installation documentation
    sudo ln -s /usr/share/dotnet/dotnet /usr/bin/dotnet
