OPC Ua error
  • #12757
    quintelosky
    Hi
    I’m using opc ua driver and I can connect to s7-1500 via opc, but I have an error when I try to connect to other opc ua server.
    I can use prosys opc ua browser but rapidscada can’t connect. Is anonymous , security mode and policy is none.
    https://ibb.co/0q4tHqc
    What can I do?
    #12758
    quintelosky
    Hi
    I solved it.
    In “…\Instances\Default\ScadaComm\Config\DrvOpcUa.View.xml”
    Change:
    <!– WARNING: SHA1 signed certficates are by default rejected and should be phased out.–>
    <RejectSHA1SignedCertificates>false</RejectSHA1SignedCertificates>
    <MinimumCertificateKeySize>1024</MinimumCertificateKeySize>
    Now works fine
    #12763
    Thank you for the update.
    Note that DrvOpcUa.View.xml affects user interface. DrvOpcUa.Logic.xml affects how the driver works.
    #12766
    quintelosky
    Hi
    Yes, but I found a problem
    DrvOpcUa.Logic.xml is overwritten with default values, and the error continues.
    If I edit drvopcua.logic, communication works fine. But, when I upload a new configuration, I lost communication and I need edit the file.
    How can I do to mantain in DrvOpcUa.Logic.xml the new changes? (I put only-read attribute but I have an error when upload a new configuration)
    #12767
    Transfer this file to your project folder
    #12768
    quintelosky
    Many thanks
    Works fine
