Forum Home › Forums › Communicating with Devices › MQTT how to filter topic?
- This topic has 3 replies, 2 voices, and was last updated 3 years, 5 months ago by
May 30, 2023 at 7:35 am #12734
KevinVt
ParticipantDear Mikhail,
I used MQTT client to subscribe one topic, like “report”, and can get data from MQTT server, but there is heartbeat data also use topic name “report”, so I can get two json message sometimes, the problems is when heartbeat message arrive, the channels data was set to null, I had used js sentence to filter data, but it did not work.
Is there any method to filter mqtt message, only get ‘real’ data and get rid of heartbeat data?
May 30, 2023 at 9:22 am #12735
In such situation, using JS is the right method. If it doesn’t work, provide more info.
June 1, 2023 at 5:25 am #12744KevinVt
ParticipantHello Mikhail,
Below 2 messages are got from MQTT Server, these topics are same, and type are different.
Message1:
Topic=【report/allpoints】 msg=【{“saleid”:”10100001″,”gateid”:”10100001001″,”type”:”report”,”time”:”2023-06-01 13:10:00″,”sequence”:”22″,”source”:”da”,”meter”:[{“id”:”1″,”status”:”1″,”name”:”VrtDev1″,”values”:{“Pf”:”0.287000″,”Uab”:”391.900024″,”Ubc”:”392.300018″,”Uca”:”391.799988″,”Ia”:”0.400000″,”Ib”:”0.000000″,”Ic”:”0.400000″,”P”:”0.000000″,”Q”:”-0.160000″,”S”:”0.160000″,”EPI”:”2257.599854″,”EPE”:”10.800000″,”EQL”:”93.199997″,”EPIJ”:”0.000000″,”EPIF”:”0.000000″,”EPIP”:”0.000000″,”EPIG”:”0.000000″,”MDMINUTE”:”0.000000″,”MDHOUR”:”0.000000″,”MDDAY”:”0.000000″,”MDMONTH”:”0.000000″,”MD”:”0.000000″,”UaTHD”:”2.210000″,”UbTHD”:”2.510000″,”UcTHD”:”2.780000″,”IaTHD”:”0.000000″,”IbTHD”:”0.000000″,”IcTHD”:”0.000000″,”VUB”:”0.220000″,”CUB”:”100.000000″,”Pa”:”0.000000″,”Pb”:”0.000000″,”Pc”:”0.040000″,”IL”:”0.000000″,”EQC”:”980.000000″}}]}】 qos level= 【AtMostOnce】
Message2:
Topic=【report/allpoints】 msg=【{“saleid”:”10100001″,”gateid”:”10100001001″,”type”:”heart_beat”,”operation”:”notify”,”time”:”2023-06-01 13:10:07″}】 qos Level=【AtMostOnce】I wrote below js code to filter the message,
—————-js code ————————let data = JSON.parse(payload);
if (data.type == “report”) {
// set values
setValue(0, new Date(data.time).getTime());
setValue(1, data.sequence);setValue(2, data.meter[0].values.Pf);
setValue(3, data.meter[0].values.Uab);
setValue(4, data.meter[0].values.Ubc);
setValue(5, data.meter[0].values.Uca);}
else
log(“Ignore HearBeat Data…”);
————————————————It can print the log “Ignore HearBeat Data…” when got message with type “heart_beat”, and at same time, all channels value were set to null.
I hope to get the channel value when got message with type of “report” and keep channel value unchange when got meesage with type “heart_beat”.
Hope you can understand what I said.
Thanks a lot.
June 1, 2023 at 10:17 am #12746
First of all, I would log some message if
data.type == "report"to check whether that section is executed. -
