Help, command send now in Scheme Editor
Forum Home › Forums › Understanding the Software › Help, command send now in Scheme Editor
Viewing 10 posts - 1 through 10 (of 10 total)
  • #6279
    Merdock
    Hi.
    I need help.
    I want to use the command send now in Scheme Editor.
    The problem is that it always sends me the value 0.
    How can I configure the value I want to send with the command, send now?
    #6282
    You can set it in the formula of output channel in Administrator.
    For example, you can write a number there.
    #6284
    Merdock
    It was simpler than I tried to do.
    #6318
    hethongscada62
    Dear Mr. Mikhail.
    I want to ask you: Can the Rapid scada send a command to third control device likes “8 channel RS485 Modbus RTU Relay board type R421A08” ?
    Does the Automatic Control module help to do this function? If it can so how to configure?
    Thanks a lot
    #6319
    Please create a separate topic. This topic doesn’t match the questions.
    Also provide an example that demonstrates how a system should behave.
    #6321
    Get a new theme, I’ll lay out a template for this relay and channel settings
    #12727
    Bang
    Hi follow up on this,
    I have to make a reset button , in which it is momentarily On.
    By using Action: Send Command, changing value to 1 , I can send another command value of 0 by using Auto Control, hence completing its purpose.
    But, I dont want to open dialog , so i tried Send Command Now, with the same auto control settings, it does change into 1 but doesnt revert back to 0.
    Thoughts ?
    #12730
    If you simply need to change command value, you can set a formula of the output channel to 1, for example.
    Do you have an input channel that changes according to a command?
    #12748
    Bang
    HI Mikhail,
    Yes I tried that formula=1 and yes I also have input channel that changes according to command.
    Whenever I put 1 in formula, the command does not reset to zero even with the Auto Control Settings configured
    But when I set command as Send Command instead of Send Command Now, it does its job. The drawback is that I have to input command in the pop up dialog
    #12755
    Could you compare the messages in ScadaServer.log in the both cases and provide screenshots?
