Viewing 15 posts - 1,576 through 1,590 (of 6,266 total)
  • in reply to: Error updating data and events #13171
    Please provide additional info:
    1. What Rapid SCADA version do you use?
    2. Press F12 in browser and check errors in the Console tab.
    in reply to: how to add new Extension option #13162
    ExtDepMysql extension should be activated in Administrator – Tools – Options – Extensions page. If the extension is correct, it appears in the drop down list in deployment profile.
    in reply to: chart plugin within same tab #13160
    I think, if chart is open in the same page, it should be open as a popup. What do you think about chart popup?
    Currently, Chart Pro supports chart views. It means that you can add a row into the views table, and open a particular chart inside common UI.
    If chart is open in a new tab in full screen mode, the Close button appears.
    in reply to: Convert decimal to hexadecimal from web browser #13159
    Currently I am waiting for an publish of instruction steps on how to migrate from V5 to V6. I will definitely want to use V6.
    Please read this topic. Instruction is inside the archive.
    in reply to: SendCommand function #13158
    Update the existing Telegram Driver to read incoming messages is in the wish list. For now, I can’t provide release date.
    in reply to: How to setup MQTT in V6 #13157
    Thank you for sharing your solution!
    in reply to: Convert decimal to hexadecimal from web browser #13130
    What is written in the device manual about sending that command?
    What Modbus function is used to send that command?
    in reply to: AutoLogin Plugin #13129
    If you creating a new project, I recommend to use Rapid SCADA 6, which has an auto login feature out of the box.
    If you prefer to use Rapid SCADA 5, could you download the above link using VPN?
    in reply to: How to set up Telegram #13128
    Replied here.
    in reply to: How to setup MQTT in V6 #13127
    1) Not yet, we can help you on the forum. The most important is establishing a connection. You already done it.
    2) It’s weird.
    Root topic can be blank for testing.
    This image contains a subscription example https://ibb.co/0X1g0Qs
    How do you enter a subscription name?
    in reply to: SendCommand function #13126
    Currently, Telegram Driver can only send messages, and cannot read incoming messages. Therefore, for now it’s not possible. It will be possible when we implement reading messages by the driver.
    in reply to: Archives by ModArcPostgreSql curcopy_current no data #13113
    “Current data copy” archive is marked as default in the configuration database. So data should be written to the archive if it is active in the Server settings.
    You should check archive status and errors in log files.
    • This reply was modified 2 years, 10 months ago by Mikhail.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #13111
    Also works for me on wine-8.13 (staging).
    To check Wine version, use wine --version command.
    in reply to: Performance in PgSQL update #13109
    Could you provide results of performance test in number of records and milliseconds?
    For executing custom scripts, may be Database Export Module is better suited.
    in reply to: Convert decimal to hexadecimal from web browser #13108
    Standard commands expect numeric command result.
    To use byte array, change command type to Binary.
