Viewing 15 posts - 1,576 through 1,590 (of 6,288 total)
  • in reply to: SQL string 8 caracters #13237
    Could you provide a screenshot?
    in reply to: add new condition ins scada scheme V5 #13234
    My be it’s better to create new components inheriting them from the existing, because in this case you have more freedom to add new features.
    in reply to: Add formula in RapidScada v6 #13233
    The instruction is here. In Rapid SCADA 6 the Formulas table was renamed to Scripts. You should copy from line 21 to 205.
    The formulas also should work on the 6th version.
    in reply to: add new condition ins scada scheme V5 #13230
    I think, it’s better to develop new components using the existing components as base classes, or as examples.
    in reply to: Require password to open ScadaAdmin #13229
    There is no password in ScadaAdmin. However, it would be useful.
    You could prevent other users to change the project it by configuring Windows access rights on the application and project folders.
    in reply to: incorrect transaction ID #13224
    ScadaClient is class is not thread safe, while you execute client.GetCurrentData in many threads.
    in reply to: New release Rapid SCADA 6.1.x #13221
    Old versions are not published. I suggest to upgrade to the latest version.
    If you need to move the software to another server without any changes, copy files and use this instruction.
    in reply to: Webstation errors #13219
    Make sure that you don’t ignore registration keys when upload the configuration. The checkbox must not be set.
    https://ibb.co/RT4kMz6
    in reply to: add new condition ins scada scheme V5 #13217
    Please provide more info related to the question.
    in reply to: Webstation errors #13216
    Open the file C:\SCADA613\ScadaAgent\Config\ScadaAgentConfig.xml and check the Directory parameter. In your case, it should be C:\SCADA613\
    After change ScadaAgentConfig.xml, restart the ScadaAgent6 service.
    in reply to: Add new conditions #13205
    I want these to work well with all of Rapid SCADA’s components and possibly other components plugins .
    It would be nice.
    Could you advise on whether I should integrate these directly or if there’s an existing model I should follow?
    Internal editor mechanism should be significantly updated to support such feature. The question is quite abstract.
    in reply to: chart plugin within same tab #13203
    We use bootstrap for displaying popups. That popups have adaptive width. We should experiment with height.
    • This reply was modified 2 years, 10 months ago by Mikhail.
    in reply to: Scada Scheme Editor without Admin #13202
    Scheme Editor is a Windows application that interacts with a web page. Administrator permissions are required to open TCP port, so web page can get and send data to the application.
    in reply to: Grafana Integration on RapidScada 6 #13197
    Is it possible to simply link Rapid Scada 6 to Influx DB Cloud?
    Yes, it’s possible. Take into account that a free Influx DB cloud tier is very limited.
    in reply to: Remote commumicator #13195
    Try asking the author, @jurasskpark, on this forum or GitHub.
