Forum Home › Forums › Runtime Bugs › Webstation Bugs › Webstation errors
- This topic has 4 replies, 2 voices, and was last updated 3 years, 3 months ago by
August 10, 2023 at 2:34 pm #13213
DonRapid
ParticipantI’m getting the following errors in the ScadaWeb log. I tried to upgrade to ChartPro but the registration key isn’t found. I think there’s a directory problem here.
Could anyone help me in finding and fixing this problem?
2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Webstation 6.1.1.0 started 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Storage FileStorage 6.1.0.0 loaded from file C:\SCADA613\ScadaWeb\FileStorage.dll 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ERR] Dictionary file not found and replaced with default file: C:\SCADA613\ScadaWeb\lang\ScadaCommon.af-ZA.xml 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ERR] Dictionary file not found and replaced with default file: C:\SCADA613\ScadaWeb\lang\ScadaWeb.af-ZA.xml 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Plugin PlgChartPro 6.0.1.0 loaded from file C:\SCADA613\ScadaWeb\PlgChartPro.dll 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Plugin PlgMain 6.0.2.0 loaded from file C:\SCADA613\ScadaWeb\PlgMain.dll 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Plugin PlgScheme 6.0.1.0 loaded from file C:\SCADA613\ScadaWeb\PlgScheme.dll 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Plugin PlgSchBasicComp 6.0.1.0 loaded from file C:\SCADA613\ScadaWeb\PlgSchBasicComp.dll 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Plugin PlgWebPage 6.0.1.0 loaded from file C:\SCADA613\ScadaWeb\PlgWebPage.dll 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Plugin PlgChart 6.0.1.0 loaded from file C:\SCADA613\ScadaWeb\PlgChart.dll 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ERR] Plugin PlgChartPro: Dictionary file not found and replaced with default file: C:\SCADA613\ScadaWeb\lang\PlgChartPro.af-ZA.xml 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ERR] Plugin PlgMain: Dictionary file not found and replaced with default file: C:\SCADA613\ScadaWeb\lang\PlgMain.af-ZA.xml 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ERR] Plugin PlgScheme: Dictionary file not found and replaced with default file: C:\SCADA613\ScadaWeb\lang\PlgScheme.af-ZA.xml 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ERR] Plugin PlgWebPage: Dictionary file not found and replaced with default file: C:\SCADA613\ScadaWeb\lang\PlgWebPage.af-ZA.xml 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ERR] Plugin PlgChart: Dictionary file not found and replaced with default file: C:\SCADA613\ScadaWeb\lang\PlgChart.af-ZA.xml 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ERR] Check PlgChartPro registration: Registration key is not valid. Computer code: =BA014E3E9D15C643-A545D69391BC07A4-01F0799CDB97304C-C90D562FD58231AD-A22064E3ED7CCC4C-50EA811F014BEC40-570A35F5C1E8E1F1-B09677AC30713606-E2A8D28A9623AE1C-623E7064B01100EB= 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins 2023-08-10 16:12:27 [PROLIANT][PROLIANT$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin 2023-08-10 16:12:28 [PROLIANT][PROLIANT$][ACT] Receive the configuration database 2023-08-10 16:12:30 [PROLIANT][PROLIANT$][ACT] The configuration database has been received successfully 2023-08-10 16:12:30 [PROLIANT][PROLIANT$][INF] The application is ready for operatingAugust 10, 2023 at 3:33 pm #13214DonRapid
ParticipantI’ve gone back to the normal Chart plugin but no data is showing up in the graph. I am however seeing data in the tables
August 11, 2023 at 9:00 am #13216
Open the file C:\SCADA613\ScadaAgent\Config\ScadaAgentConfig.xml and check the Directory parameter. In your case, it should be C:\SCADA613\
After change ScadaAgentConfig.xml, restart the ScadaAgent6 service.August 11, 2023 at 2:08 pm #13218DonRapid
ParticipantI did this but the problem persists. What else could I try?
August 14, 2023 at 6:58 am #13219
MikhailModeratorMake sure that you don’t ignore registration keys when upload the configuration. The checkbox must not be set.
https://ibb.co/RT4kMz6 -
