Add new conditions
Forum Home › Forums › Development and Integration › Add new conditions
  • #13200
    mgmouk
    I’m working on a new component plugin for scada scheme. I’ve added conditions for properties like background color, text, visibility, size, blinking, and rotation.
    I want these to work well with all of Rapid SCADA’s components and possibly other components plugins . Could you advise on whether I should integrate these directly or if there’s an existing model I should follow?
    I’d appreciate your insights and guidance.
    Best regards,
    #13201
    Now it is not very convenient, since it is necessary to develop for the Schema Editor in the 5th version, and at the same time make the plugin for the 6th version. It will be easier when the schema editor is ported to the 6th version.
    #13205
    It would be nice.
    Internal editor mechanism should be significantly updated to support such feature. The question is quite abstract.
