SQL string 8 caracters
Forum Home › Forums › Communicating with Devices › SQL string 8 caracters
  • #13235
    shotscope
    I have implemented a dashboard where I query data from a SQL Server DB.
    All looks good except the string.
    It is always limited to 8 car.
    is there any workaround I can use to display more car ?
    #13237
    Could you provide a screenshot?
    #13239
    shotscope
    Thank you for your reply.
    Here is the picture : https://ibb.co/mHYpvbs
    You can see the data I have in my database and in Rapid Scada interface I see it is truncate to 8 car.
    #13242
    Thank you for the screenshot.
    In Rapid SCADA 6 channels of the string type may contain more then 8 characters.
    However, the DB import driver currently does not support long strings. The driver needs an update to implement the required feature.
    #13245
    shotscope
    If I understand well, 2 problems
    – SCADA channel that may contains > 8 car –> solved in version 6 (I can upgrade my system)
    – Driver must be modified to take in account string > 8 car
    Sorry if it is studi question but how to modifiy the driver ?
    Any source code somewhere ?
    #13246
    shotscope
    As a workaround:
    In my SQL table I created 2 columns. and in my program I split the strting in with 8 car max.
    In SCADA I created 2 fields showing column 1 and column 2
    #13251
    The above description is correct.
    1. Change the driver by yourself using the source code.
    2. Sponsor the update, and we would implement the required feature.
    Driver’s source
    See DrvDbImport projects. For example, DrvDsOpcUaServer supports long strings.
    #13252
    Good workaround. Thank you for the idea.
