Viewing 15 posts - 3,061 through 3,075 (of 6,219 total)
  • in reply to: scheme view stuck with loading animation #8606
    This issue is interesting and unusual. Considering the fact that we anyway will rewrite the entire web application, I suppose, we should check the new web app if this issue still occurs and then fix it.
    dotNET5 doesn’t support WebForms technology that is currently used that’s why we have to create the web app from scratch.
    The subnodes are the channels grouped by device. That’s why subnodes are the same. All devices are displayed.
    in reply to: Accessing Scada.Client.DataAccess() #8603
    In formulas, only limited amount of information is accessible. To access to the configuration database and archives, you need to develop a module using C#.
    in reply to: scheme view stuck with loading animation #8592
    Yes, the issue is reproduced. But demo server has very low CPU and RAM.
    What are the parameters of your server? Is it Linux or Windows?
    in reply to: API for Integration #8591
    As an option, I would develop a utility to export XML and/or DAT files to the required RDBMS.
    in reply to: about SCADA V6 #8590
    If we found a sponsor, we can implement uploading a project from Administrator to PostgreSQL database.
    In my opinion, SQLite is not enough, because remote access is quite useful in many cases.
    in reply to: Silent server crash #8588
    Yes it is, see v5.1.4.2
    Server update for testing.
    The command queue is in the Server service.
    • This reply was modified 5 years ago by Mikhail.
    in reply to: Transfer File from Computer to Rpi #8579
    Thanks for the useful notes. Some comments below.
    I then went through Administrator on windows and changed all localhost settings to now look at the remote server eg. 192.168.1.10
    Could you provide a screenshot of this to check?
    This is most likely a config issue but I had to re transfer all the plugins to the Rpi opt/scada/ folder
    DLLs of the modules should be presented on RPi. WinSCP is good for file transfer.
    To activate the ChartPro plugin, I had to go chmod ug+rw WebSettings.xml
    This is a known issue. We will fix it in the future.
    in reply to: Sendig email: Error: incorrect command data #8577
    Please open the properties of KpEmail.dll and check the version. What is the file version?
    Also try specifying a particular email:
    test@gmail.com; Subj; Text
    in reply to: Sending a Signal to a Scada Unit #8572
    You can’t send a command from a formula. However, you can set input channel value from a formula.
    To send commands according to conditions, Automatic Control Module was created.
    in reply to: Few question about avialable feautres #8571
    Currently to export data on change, use the existing DB export module.
    The version 5 can only export data to 3rd party DB. Flexible archives possible in v6.
    in reply to: LED not working at output channel #8567
    Output channel only declares a command. It doesn’t send command itself, and it doesn’t store any value.
    To display any kind of value, you need an input channel which stores a value.
    in reply to: Sending a Signal to a Scada Unit #8566
    If you need to send commands automatically according to some conditions, Automatic Control Module would help you.
    in reply to: Few question about avialable feautres #8562
    I hope till the end of 2021. But it is not exactly.
    in reply to: LED not working at output channel #8561
    Led can blink if you bind it to input channel. You should create a formula that changes input channel value every second, for example.
    Something like
    public double Blink()
      return DateTime.UtcNow.Second % 2 > 0 ? 1 : 0;
    Then use this formula in the input channel row.
