RSAdmin: TreeView OutputChannel only show InputChannel Nodes
Forum Home › Forums › Runtime Bugs › RSAdmin: TreeView OutputChannel only show InputChannel Nodes
  • #8597
    zzz
    https://pasteboard.co/JUWOKpN.png
    https://paste.pics/3146f4b715a0467b0f61692d71628ebe
    • This topic was modified 5 years, 7 months ago by zzz.
    • This topic was modified 5 years, 7 months ago by Mikhail.
    #8599
    zzz
    The OutputChannel list on right pane looks corret, but OutputChannel subnodes in left treeview is showing identical subnodes from InputChannel. Clicking on them show the correct OutputChannel, but majority of them are empty.
    Is this feature (showing all commlines regardless of whether they have outputchannel) or bug ? If feature, I’d suggest, hiding comm-lines without outchannel, make more sense.
    #8601
    The output channel number does not have to be the same as the input channel number. In the input channel, you make a binding, which output channel is associated with it.
    #8602
    zzz
    I understand that.
    My point is that the comm-line subnodes under OutputChannel are significantly more than the output entries. I have 50 comm-lines but only less than 10 output channels are defined in 3 comm-lines.
    90% of the comm-line are empty.
    It’s pointless to show them all ,because majority of those communication lines don’t have a output channel.
    #8605
    The subnodes are the channels grouped by device. That’s why subnodes are the same. All devices are displayed.
