Forum Home › Forums › Runtime Bugs › Webstation Bugs › scheme view stuck with loading animation
- This topic has 6 replies, 2 voices, and was last updated 5 years, 7 months ago by
March 29, 2021 at 4:03 am #8581
JW
ParticipantAfter a few click between schemes, the scheme is stuck with loading animation.
refresh this url will not resume
xxx.com/scada/View.aspx?viewID=21
refresh thi url will resume
xxx.com/scadascreen cap
https://drive.google.com/file/d/12usW761By5bdMw2ZGQ4fD4Y1J-GB6wOy/view?usp=sharingweb log
2021-03-29 11:39:11 <os-server><www-data><ACT> Request SCADA-Server state 2021-03-29 11:39:11 <os-server><www-data><ERR> Incorrect SCADA-Server response to state request 2021-03-29 11:39:11 <os-server><www-data><ACT> Disconnect from SCADA-Server 2021-03-29 11:39:11 <os-server><www-data><ACT> Connect to SCADA-Server "localhost" 2021-03-29 11:40:12 <os-server><www-data><ACT> Request SCADA-Server state 2021-03-29 11:40:12 <os-server><www-data><ERR> Incorrect SCADA-Server response to state request 2021-03-29 11:40:12 <os-server><www-data><ACT> Disconnect from SCADA-Server 2021-03-29 11:40:12 <os-server><www-data><ACT> Connect to SCADA-Server "localhost" 2021-03-29 11:44:05 <os-server><www-data><ACT> Request SCADA-Server state 2021-03-29 11:47:49 <os-server><www-data><ACT> Request SCADA-Server state 2021-03-29 11:48:38 <os-server><www-data><ACT> Logout: user. IP address: 127.0.0.1 2021-03-29 11:48:42 <os-server><www-data><ACT> Request SCADA-Server state 2021-03-29 11:48:42 <os-server><www-data><ACT> Login: user (Guest). IP address: 127.0.0.1 2021-03-29 11:48:42 <os-server><www-data><ACT> User information has been updated. IP address: 127.0.0.1. Session: EE06B64156E60F769A17C026 2021-03-29 11:48:42 <os-server><www-data><ACT> Retrieve components from the installed pluginsserver log
2021-03-29 11:38:43 <os-server><root><ACT> Disconnect client 127.0.0.1 2021-03-29 11:39:11 <os-server><root><ACT> Connect to client 127.0.0.1 2021-03-29 11:39:11 <os-server><root><ACT> The user ScadaWeb is successfully authenticated 2021-03-29 11:40:11 <os-server><root><ACT> Disconnect client 127.0.0.1 2021-03-29 11:40:12 <os-server><root><ACT> Connect to client 127.0.0.1 2021-03-29 11:40:12 <os-server><root><ACT> The user ScadaWeb is successfully authenticated 2021-03-29 11:48:42 <os-server><root><ACT> Check username and password for user. Result: passedMarch 29, 2021 at 6:03 am #8582JW
ParticipantAfter brief test, seems only happens when using Firefox. But not 100% sure at the moment.
March 29, 2021 at 7:05 am #8584JW
ParticipantThe issue can be reproduce on the official demo website.
http://rapidscada.net/scada/Login.aspx
Use Firefox
Click “Home scheme” and “Server room scheme” repeat a few timesscreen cap
https://drive.google.com/file/d/1WrJHLx8mlKARNsTVEk-HH14z4gVD7aad/view?usp=sharingMarch 29, 2021 at 2:23 pm #8592
MikhailModeratorYes, the issue is reproduced. But demo server has very low CPU and RAM.
What are the parameters of your server? Is it Linux or Windows?March 29, 2021 at 3:35 pm #8593JW
ParticipantI tried on 3 of my servers, both are Linux
1. 2 core cpu + 1GB ram (+2gb ssd swap)
2. 4 core 8th gen i5 + 8GB ramThe issue appear on both while I am using Firefox from my laptop within 1~3 minute of clicking.
I tried Chrome, after clicking about 10 minutes, they are still working.March 30, 2021 at 3:03 am #8596JW
ParticipantI did another test on my laptop as server
Windows 10, i5 + 16GB RAMUsing Firefox both locally and remotely will have this issue.
There is an error on Firefox when stuck on loading.
ns_error_not_initialized schemeform.jshttps://drive.google.com/file/d/1I-vHlothMHODKWG7C_nNVINvF_xL367a/view?usp=sharing
March 30, 2021 at 2:22 pm #8606
MikhailModeratorThis issue is interesting and unusual. Considering the fact that we anyway will rewrite the entire web application, I suppose, we should check the new web app if this issue still occurs and then fix it.
dotNET5 doesn’t support WebForms technology that is currently used that’s why we have to create the web app from scratch. -
