Forum Home › Forums › Rapid SCADA on Linux Controllers and Raspberry Pi › Transfer File from Computer to Rpi
- This topic has 13 replies, 7 voices, and was last updated 5 years, 8 months ago by
February 6, 2020 at 3:25 am #6497
scadarapid
ParticipantHello RapidScada admin
After I have finished project on my computer then I need to transfer to Raspberry pi.
1.Which files do I have to transfer from computer to Raspberry Pi.
2.its same as previous version or not.Thank you so much
February 6, 2020 at 2:32 pm #6498
February 12, 2020 at 3:05 am #6533scadarapid
ParticipantHello, Admin
Version on my computer
Rapid SCADA 5.8.0 (size 14.4 MB, released on January 28, 2020)Version on my Rpi
Rapid SCADA 5.8.0 Mono (size 12.9 MB, released on January 28, 2020)thank you so much.
February 12, 2020 at 3:29 pm #6534
MikhailModeratorIn Administrator create a new deployment profile for Raspberry. Upload all the configuration except Server settings (because they have different file paths).
January 2, 2021 at 12:46 am #7906Artos9
ParticipantHi Mr Mikhail,
I searched all forum topic, but I haven’t find more information how to upload project to Raspberry Pi created on Windows.Is possible to upload directly from Windows OS to Raspberry Pi Apache server(localhost)?
Thank you so much
This reply was modified 5 years, 10 months ago by
Artos9.
January 2, 2021 at 10:02 am #7911
In your project open Server – Common Parameters and update directories. You can click “Default for Linux” there.
Then use the above advice.
Do you know how to create a new deployment profile?January 2, 2021 at 11:48 am #7913Artos9
ParticipantThanks you. It’s clear.
I know how to create new deployment profile, but set parameters correctly aren’t clearly.January 3, 2021 at 1:26 am #7921
MerdockParticipantHi.
The way I pass the projects to RaspberryPI is:
1- I install Rapidscada is RaspberryPI and then I verify that it works correctly.
2 – I create the project in Windows and verify that it works correctly.
3 – I create a copy of the windows SCADA folder in another place.
4 – I delete the ScadaServerSvcConfig.xml file located in the copy \ SCADA \ ScadaServer \ Config \
5- I search all the folders within the copy \ SCADA \ Scadaxxx \ config \ *. Xlm and edit the paths to match the Linux paths.
6- I edit the ScadaCommSvcConfig.xml file located in the copy \ SCADA \ ScadaComm \ Config. so that the names of serial ports and other devices match Linux.
7- I overwrite the SCADA Folder of the rasberryPI SD with the edited folder. usually located at: / opt / scada /
8. Be careful with the name, in Windows it is SCADA in uppercase and in Linux it is scada in lowercase.I hope it helps.
Regards.January 3, 2021 at 6:20 am #7922kumajaya
ParticipantMy English not good enough to explain but I can upload RS project from Windows to Linux over internet easily.
January 3, 2021 at 9:55 am #7924
MikhailModeratorI know how to create new deployment profile, but set parameters correctly aren’t clearly.
If something doesn’t work, make screenshots of your deployment profile settings.
January 3, 2021 at 11:30 pm #7925
MerdockParticipantMy English not good enough to explain but I can upload RS project from Windows to Linux over internet easily.
Let’s see if I understand what you mean.
You have a Linux PC running Rapidscada elsewhere.
You do the project on a Windows PC.
You want to transfer the project over the internet to your Linux PC.As far as I know, to do this you must use a third party remote file management program.
Regards.
January 4, 2021 at 7:46 am #7928
manjey73ParticipantOnly for the initial installation and migration of driver libraries, for example. Edit the Instance name and key for the Agent. Otherwise, the project is transferred using the Agent from Windows to Linux without problems.
WinSCP and SSH connection are enough to copy and install files.
March 26, 2021 at 10:23 pm #8578Bill_A
ParticipantThis may help someone or me in the future when looking to how to do this.
Situation
Rapid Scada installed and operational on Windows and a Rpi 4.
Rapid Scada project built and tested on Windows and now looking to transfer to Rpi 4Complete what has been mentioned above
“In Administrator create a new deployment profile for Raspberry. Upload all the configuration except Server settings (because they have different file paths).”The program then transferred across successfully and was running on the Rpi 4. I then went to the server and changed file paths from Windows Default to Linux defaults.
I then went through Administrator on windows and changed all localhost settings to now look at the remote server eg. 192.168.1.10
I can now see the data in line stats from the server in the administrator app.
This is most likely a config issue but I had to re transfer all the plugins to the Rpi opt/scada/ folder. I did this by file transfer over vnc to the desktop and then copy paste from desktop to opt/scada/ folder.
To activate the ChartPro plugin, I had to go chmod ug+rw WebSettings.xml in var/www/…. folder. If you have an issue activating it, it comes up with a fault on the web interface.
Hope this helps someone in the future.
Further..
To enter registration codes into the program. I transferred the entire project inc. server option.
I then loaded administrator application on Rpi, created new project and performed a download. Then went into each plugin and completed registration.March 28, 2021 at 6:33 am #8579
MikhailModeratorThanks for the useful notes. Some comments below.
Could you provide a screenshot of this to check?
DLLs of the modules should be presented on RPi. WinSCP is good for file transfer.
This is a known issue. We will fix it in the future.
