i would like to use output channel to blink the LED in .sch file.
let’s say, to switch ON the motor, i send the command “1” on output channel 701 and i wrote in LED condition
if output channel 701, values =1, LED blink Green.
why LED is not working for output channel instead for input channel it’s working.
do i have to set the formula somewhere to read that value of output channel by server ?
Output channel only declares a command. It doesn’t send command itself, and it doesn’t store any value.
To display any kind of value, you need an input channel which stores a value.
