Viewing 15 posts - 376 through 390 (of 6,387 total)
  • in reply to: multi channel support needed in mimiceditor #17259
    Could you explain the question and provide some examples?
    in reply to: Working on a project pulled from another PC #17258
    It is possible simply copy the project folder to another machine. But it’s not comfortable to synchronize them.
    I recommend a private repository on GitHub to exchange between different machines and control the project versions.
    If the 1st PC is a workstation, and the 2nd is a production server, you can upload the project from the 1st to the 2nd with the Administrator application for execution.
    in reply to: Can RapidScada act as an OPCUA server #17257
    There is no software limits. It depends on the computer and network performance.
    Projects may include hundreds of communication lines.
    in reply to: memory problem #17252
    The browser can manage memory cleanup using its own algorithms.
    1. What versions of the web browser do you use?
    2. What was the maximum memory consumption achieved by the page?
    in reply to: Custom Command #17251
    2. In the Modbus template, add a new command, set the Data block to Custom, the function code to 7.
    3. According to the Modbus specification, Input Registers are read-only. So it’s not possible to write them. You can try creating a separate command with the 0x06 code.
    in reply to: OPC DA to OPC UA Server Question Communicator #17250
    > I was able to get your software to recognize an OPCUA server and its all working now.
    That’s nice.
    > if I want to work on an project on one PC and then copy it over to another PC how do I do that?
    Please create a separate topic for that question.
    in reply to: Can RapidScada act as an OPCUA server #17248
    Yes, activate the OpcUaServer data source that can be found in Instances – Default – Communicator – Data Sources.
    • This reply was modified 11 months, 1 week ago by Mikhail.
    in reply to: memory problem #17241
    That problem has not been observed before.
    What versions of the web browser and Rapid SCADA do you use?
    in reply to: modal develop in mimiceditor #17236
    It would be useful, but this is not possible for now. I saved the idea and will see what can be done. I plan to return to work on the new editor in January.
    in reply to: Some channels muted in Notifications #17235
    Creating a channel is just writing its properties into the XML file.
    To find a cause, it would be useful to analyze the channel properties and events.
    in reply to: Failed to fetch. #17232
    > So if this issue occurs, should we address it or simply ignore it?
    If the issue is not visible to a user, it can be ignored.
    in reply to: OPC DA to OPC UA Server Question Communicator #17231
    System requirements are here.
    Minimum Windows 10.
    Can I connect to it using Rapidscada to access the OPC data on that machine?
    Likely, yes.
    in reply to: Automatic Control Module – Registration key invalid #17230
    If you have any issues, please contact us.
    in reply to: Is there a better way to batch modify channel attributes? #17225
    In the Administrator app, select Tools – Project Tools – Export Table. Then select an output format, and channels to export.
    in reply to: Failed to fetch. #17224
    Do the errors occur when a new table view is open, or when a table view is unloaded?
    Also please make a screenshot of the error requests in the Network tab.
