Viewing 15 posts - 3,181 through 3,195 (of 6,392 total)
  • in reply to: Retry scheme ? #8747
    Could you explain the question?
    in reply to: Tracking state in formula, a bad idea ? #8746
    I wonder why CalcDRCnls() has to be called after average calculation?
    Which line numbers of the source code do you mean?
    in reply to: Chart Pro with application error #8745
    “Method not found” error is caused because of Webstation version and the plugin version mismatch.
    The second screenshot: provide access right to all files in the config directory.
    in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8744
    So Pls let me know how to uninstall Rapid Scada Software in Raspberry Pi?
    The uninstallation instruction is in the package ZIP.
    But I recommend not to uninstall Rapid SCADA, because you just need to fix file access rights. If you have issues with changing file access rights, post the related screenshots on the forum.
    in reply to: Communication stops on device timeout #8725
    Line Parameters – Main Parameters, then Communication Channel group box and the Properties button.
    it is waiting there for few seconds without communicating with other device which is still turned ON
    What date and time on your screenshot?
    in reply to: Loggin server error #8724
    Check C:\SCADA\ScadaServer\Log\ScadaServerSvc.log for the error details.
    in reply to: Capture Reading at a Certain Time of the Day #8723
    Use the formula:
    MonthBeg() ? Val(101) : Val()
    where 101 is the referenced channel.
    You can find MonthBeg implementation in the Formulas table if interested.
    The channel must be of the calculated real or calculated discrete type.
    in reply to: Chart Pro with application error #8722
    If you already did it, repeat.
    in reply to: Chart Pro with application error #8721
    You should provide write access to the configuration directory and configuration file:
    C:\SCADA\ScadaWeb\config\
    C:\SCADA\ScadaWeb\config\WebSettings.xml
    or
    /opt/scada/ScadaWeb/config/
    /opt/scada/ScadaWeb/config/WebSettings.xml
    in reply to: Communicating with Kepware OPC server #8713
    in reply to: Communication stops on device timeout #8712
    On the screenshot the line seems working.
    Also please provide a screenshot of your communication channel properties.
    in reply to: Does Rapid SCADA support OPC UA #8711
    Rapid SCADA does support OPC UA. You should provide the error details.
    in reply to: Communication with kepware OPC on window 10 #8710
    You should select an appropriate topic to discuss this issue or create a new one. As I wrote, the cause is not related to OPC and Kepware.
    in reply to: Calc value from multiple device #8701
    Set the type of channel 163 to “Calculated real”, and set Signal to blank.
    I would insert logging in the module you working on, and see the actual sequence.
    Server calculates formulas for “calculated” channels in the main thread, while data from Communicator are coming from another thread.
    • This reply was modified 5 years, 6 months ago by Mikhail.
