Forum Home › Forums › Communicating with Devices › Modbus › Accessing Schneider PM810MG via Modbus RTU
- This topic has 1 reply, 2 voices, and was last updated 5 years, 10 months ago by
January 13, 2021 at 4:38 pm #8019
kumajaya
ParticipantDevice template:
<?xml version="1.0" encoding="utf-8"?> <DevTemplate> <Settings> <ZeroAddr>true</ZeroAddr> <DecAddr>true</DecAddr> <DefByteOrder2 /> <DefByteOrder4 /> <DefByteOrder8 /> </Settings> <ElemGroups> <ElemGroup active="true" tableType="InputRegisters" address="1104" name="Current"> <Elem name="Average Current" type="ushort" byteOrder="" /> </ElemGroup> <ElemGroup active="true" tableType="InputRegisters" address="1122" name="Voltage LL"> <Elem name="Average Voltage LL" type="ushort" byteOrder="" /> </ElemGroup> <ElemGroup active="true" tableType="InputRegisters" address="1127" name="Voltage LN"> <Elem name="Average Voltage LN" type="ushort" byteOrder="" /> </ElemGroup> <ElemGroup active="true" tableType="InputRegisters" address="1142" name="Power"> <Elem name="Total Power" type="ushort" byteOrder="" /> </ElemGroup> <ElemGroup active="true" tableType="InputRegisters" address="1179" name="Frequency"> <Elem name="Frequency" type="ushort" byteOrder="" /> </ElemGroup> <ElemGroup active="true" tableType="InputRegisters" address="1699" name="Energy"> <Elem name="Energy" type="ulong" byteOrder="67452301" /> </ElemGroup> </ElemGroups> <Cmds /> </DevTemplate>Formula to convert energy register based on https://www.se.com/id/en/faqs/FA212766/ info:
double Mod10(double val) {
ulong v = Convert.ToUInt64(val);
return ((v >> 48) * 1000000000000) + (((v >> 32) & 0xFFFF) * 100000000) + (((v >> 16) & 0xFFFF) * 10000) + (v & 0xFFFF);
@Mikhail Am I doing right? Or is there a better solution?January 14, 2021 at 1:34 pm #8024
MikhailModeratorWho are crazy authors of such algorithms…
Please scroll down this Russian version the article, there is a formula:
double Convert(double x) { return x<32768 ? x*760/32767 : -(double)(ushort)(~(ushort)x|128+1)*210/9182; }May be it can be example.
To be honest, I didn’t understand Mod10 calculations. If you change your question to something more specific, what calculation do you need, I’ll try to help. -
