Viewing 15 posts - 2,986 through 3,000 (of 6,392 total)
  • in reply to: opc da do not work #9352
    OPC DA is a black box. I strongly recommend to move to OPC UA because it is more reliable, and .NET5 and higher will not support classic OPC.
    I can provide the source code of the driver if needed.
    Also try this advice.
    in reply to: scheme loading failed. Try to reload scheme #9351
    The answer is here.
    in reply to: Database SQL usage #9325
    5.8.3
    I think, 5.8.2. If needed, it the module can be updated to be compatible with 5.8.3.
    • This reply was modified 5 years, 2 months ago by Mikhail.
    in reply to: ScadaAdmin.exe can not be started #9323
    This error message means that ScadaAgent does not open TCP port 10002. Check agent configuration and log file.
    in reply to: ScadaAdmin.exe can not be started #9320
    Make sure that the Temp subdirectory exists.
    If it doesn’t help, provide error details from ScadaAdmin.err
    in reply to: sevice start fail for built version 5.8.3 #9314
    the service can be installed, after stop virus-killer software.
    Which antivirus software?
    in reply to: Export data module manual exist? #9313
    All docs were moved to web. Link
    in reply to: Installation failure #9308
    The user interface is very close between 5.7 and 5.8. You should use the latest version of Rapid SCADA.
    in reply to: How to install a free plugin #9306
    Image pack is a set of images. It’s not needed to somehow install it. Just use the images in the Scheme Editor.
    in reply to: Installation failure #9302
    This question is not relate to the topic “Installation failure”. Please create a new topic in an appropriate subforum and provide a screenshot of your Table Editor.
    in reply to: Installation failure #9299
    Please contact me by email to get a quote. Another option is a remote consulting service to help your engineers to make a project using Rapid SCADA.
    in reply to: Auto control module settings #9296
    About the 1st solution:
    It also good. You can improve it by cancelling the command in the output channel formula if relay is matched.
    in reply to: Auto control module settings #9295
    1. It means that a command is sent when the trigger changes from the fired state to waiting state.
    2. If I understand the task correctly, I would prefer the following (your 2nd solution):
    Create an input channel means “relay needs synchronization”.
    Create a trigger on this channel, set repeat period 10 seconds (for example) for the trigger. Send command to set a relay by the trigger.
    in reply to: KpMQTT and Thingsboard #9294
    For your task, you don’t need formulas in the configuration database.
    in reply to: KpMQTT and Thingsboard #9293
    This error is caused by an incorrect formula in the Formulas table or in the Input channels table. Formulas use C# syntax, not C/C++.
