Viewing 15 posts - 2,281 through 2,295 (of 6,391 total)
  • in reply to: Channel Status and Channel Value #11629
    To display channels statuses as numbers, create extra channels of the calculated type that contain statues.
    in reply to: Number to be displayed at WebStation #11628
    if (Cnl=65535) return 0; has wrong syntax. C# uses == as equality operator.
    in reply to: Cnl vs Val #11627
    Please provide clear description of the issue.
    in reply to: Real vs Calculated Real #11626
    “Real” channels are measured by devices.
    “Calculated” channels are calculated based on real channels.
    in reply to: Rapid SCADA bug reported?? #11625
    To display status as a number, use Stat(102) formula.
    in reply to: Table Summary (More document support needed) #11624
    Using too many channels in a one view will be slow and not comfortable for an operator.
    in reply to: Table #11623
    Please provide screenshots that explain your question.
    in reply to: Table – More comments #11622
    Probably there should be another report for current data. I will add it to the wish list.
    in reply to: Error #11621
    If Communicator cannot connect to the Server app, make sure that Server is OK.
    in reply to: v6 protocol document mismatch #11620
    I’ve updated Application Protocol 3.0.pdf
    Use ScadaTestClient-v6.zip from this folder to test getting file info.
    I will check why file length is 0.
    in reply to: v6, DrvDsMqtt not publishing anything. #11618
    2022-11-16 15:16:52 [wst1][appstack][ERR] Error calling the Start method of the MqttServer data source:
    System.InvalidOperationException: Collection was modified; enumeration operation may not execute.
       at System.Collections.Generic.List
    1.Enumerator.MoveNext()
       at Scada.Comm.Engine.CommLine.SelectDevices()
       at Scada.Comm.Drivers.DrvDsMqtt.Logic.MqttDSL.FillDeviceTopics()
       at Scada.Comm.Drivers.DrvDsMqtt.Logic.MqttDSL.Start()
       at Scada.Comm.Engine.DataSourceHolder.Start()
    Does this error appear every time when you restart Communicator?
    in reply to: scada v6 archive error #11617
    To enter correct options, use the Administrator app.
    in reply to: scada v6 archive error #11616
    InfluxDB can be used for historical archives only. It doesn’t work with current data and events.
    For example, I use the following options for InfluxDB archive:
    Connection = InfluxConn
    Deadband = 0.1
    DeadbandUnit = Absolute
    IsPeriodic = false
    LogEnabled = true
    PullToPeriod = 0
    ReadOnly = false
    Retention = 365
    WriteOnChange = true
    WriteWithPeriod = true
    WritingPeriod = 1
    WritingPeriodUnit = Minute
    You should configure a connection.
    in reply to: Maximum number of Modbus devices #11615
    If you add thousands of devices, especially with master-slave polling, you may face network performance issues that should be solved individually.
    in reply to: The login page of the web always prompts an error #11614
    2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Webstation 6.0.0.0 started
    2022-11-18 16:48:18 [SCADA6][SCADA6$][INF] The application is ready for operating
    It takes 5 seconds, which is good. The web app is started when a request is initiated by a browser, so you need to click the refresh button after uploading configuration.
    This behavior is on Windows. Linux web service does not need user action.
