– In the code ClientBase.cs, the last field is ClientMode. The protocol document left out the last field ClientMode. It seems to need update.
– File length field in Fnc 0x0102 GetFileInfo response seems to be always 0. Maybe should mark as unimplemented.
– How do you get path to logs ?
When I try to use the following path I only got error 0x8103 0x8102:
\x03\x04\x00\x00 //Server+Log
\x1e\x00ModArcInfluxDb_MinCopy.log.bak // just b/c this log is bigger
// or RelativePath(TopFolder.Server, AppFolder.Log, "ModArcInfluxDb_MinCopy.log.bak");
// IllegalArgument
This topic was modified 3 years, 9 months ago by
zzz.
