Viewing 15 posts - 2,251 through 2,265 (of 6,391 total)
  • in reply to: How to manage string data in Version 6 #11710
    It is possible in case a driver supports strings. Currently, the following drivers can provide string data: OPC UA and OPC Classic.
    What communication protocol and driver do you plan to use?
    in reply to: Automatic Control Module Channel Data (NO) trigger #11707
    Triggers of the “On channel data” type fire when channel value changes. In your case, may be an “on command” trigger would be more appropriate.
    in reply to: How to connect a Profinet device? #11701
    Please write about results.
    in reply to: Map code #11696
    what is the input so that the pin is red?
    It should be a channel that displays location status. For example, some tag of a device mounted on the site.
    in reply to: How to connect a Profinet device? #11695
    May be you can try this OPC server https://www.matrikonopc.com/drivers/opc-siemens.aspx to integrate Profinet and Rapid SCADA.
    in reply to: Map code #11691
    How to turn the map pin to green if >0 and turns red if 0”
    Use a channel formula mentioned above or similar.
    in reply to: Map code #11687
    Unfortunately, wetransfer.com does not work in Russia, so I can’t check the file.
    Please upload the file to another file hosting.
    in reply to: Ошибка ASP.login_aspx #11684
    The above error means that ASP.NET has not been properly installed.
    If you are starting from scratch, I suggest to try Rapid SCADA 6.
    This forum is in English. If you prefer Russian, use https://forum.rapidscada.ru/
    in reply to: Map code #11683
    Probably, you should create a new channel of the calculated type with the formula
    Val(101) <= 1 ? 1 : -1; Stat(101)
    where 101 is the source channel number
    in reply to: Map code #11682
    According to the manual: “0 – channel not specified; positive channel value means the location is normal, otherwise the location needs attention”.
    So channel formula might be: Cnl <= 1 ? 1 : -1
    in reply to: Channels Communication and Reset #11681
    The the module is required to send commands automatically according to the specified conditions.
    I recommend to get the current time once:
    DateTime curTime = DateTime.UtcNow;
    in reply to: Export channel data to excel for longer periode of time #11674
    May I know what is the proper procedures to install V6?
    Instructions will be created soon.
    How about the existing V5 projects?
    There will be a converter utility.
    Do I need to uninstall V5 first?
    It’s possible to use both on the same machine. But it is easier to deploy a new virtual machine for v6.
    in reply to: Channel Status and Channel Value #11673
    I mean that channel status can be written as value of another channel.
    in reply to: Number to be displayed at WebStation #11672
    Please read this. Item 7
    in reply to: Cnl vs Val #11671
    Cnl and CnlVal are variables.
    Val() and Stat() are functions.
